Results 1 to 8 of 8
Thread: Toyota Supercharger Calculator. Beta.01
    Chiba
    Default Toyota Supercharger Calculator. Beta.01
    Ok, so I've been playing with excel, and come up with a bit of a supercharger calculator for the SC12 and SC14 superchargers.
    Can you guys have a look at it and make sure all the algorithms etc are good. There are a few dodgy ones in there, I just need another point of view to help me polish it off.
    Any comments or suggestions are welcome.
    http://www.jdmlevin.com/files/BlowerCalculator.xls
    User Conversion King
    NWA
    Default Re: Toyota Supercharger Calculator. Beta.01
    looks ok. basic.
    1st thing: its probably worth including supercharger efficiency.
    also, work with air mass (proportional to moles) entering engine, not volume. its easier to work with changing pressure/temp/volume.
    hello
    Jul 2009
    The pulley ratios are incorrect, you have them setup as geared down at the moment.
    Example: With 7500RPM limit and an SC14, it says the charger speed is only 5454RPM, which is a gear down of 1.375:1 (1.375 turns of the motor to 1 turn of the supercharger).
    If you change the formula in cell I45 to "=I43/F28", this will give you the correct pulley sizes.
    EDIT: Could you allow a custom supercharger section in your spreadsheet? Thought it might be handy for those who want to use a different supercharger then the SC12/14 units
    Last edited by knightrous; 17-08-2009 at 11:13 AM. Reason: Forgot to add something.
    Chiba
    Yea, I knew something was screwy there.... I got sidetracked... yea...
    I will be adding the ability to add your own chargers, I just want to get the rest of the calculations working first.
    If you can help me get the specs of some common chargers, that would be awesome.
    Edit: Um, cell I45 is already '=I43/F28'
    Jul 2009
    It wasn't in the copy I downloaded
    Chiba
    Hmm. I could have updated it in a flurry of updates the other night... Re-download it and see how you go.
    Jul 2009
    Odessa
    hm, I can try to make online version of this calc.
    Soarer - a bit closer to heaven...
    Victoria, Mt Macedon
    Looks like you might have been basing things on this one, but there is a good SC calculator from Sprintex (though without SC12 or 14) linked to in this post.
  1. Toyota Distributor and DLI Ignition Systems - explanation and guide
    Last Post: 14-11-2010, 01:42 AM
  2. Replies: 0
    Last Post: 20-07-2006, 12:18 PM
