Results 1 to 4 of 4
Thread: help installing 5sfe camshafts?
    Default help installing 5sfe camshafts?
    can anyone help me with the camshaft timing on a 5sfe I have just changed a head on a camry and installing the cams and there is about 3 different marks on each cam so not sure which ones to line up?
    Default Re: help installing 5sfe camshafts?
    It might help to eliminate the wrong positions if you note that both intake and exaust valves should be closed at TDC.
    Junior Member Backyard Mechanic DrNick's Avatar
    May 2008
    oh yes its not that straightforward as there are assembly reference marks on the cam gear, which are not the ones you need.
    you install the intake one first , the orientation is not so important as you only need to mesh it properly with the gear on the exhaust cam, then you put the exhaust one in.
    it will be easier with the service manual - ive got one of them on my website here
    http://suprawa.com/technical
    if you cant find it in that one then let me know and i'll get around to uploading another version that ive got on my pc at work.
    wa
    basically just put in the 1 cam (usually he one with the lock bolt,split gear)
    there will be 1 dot and 2 dots on each cam.
    Just line up the 1 dot on each cam and make sure when you turn the cam around to the 2 dots they line up as well.
    Once they are bolted in remove the 10mm lock bolt and then youre done.
  1. Replies: 6
    Last Post: 26-09-2016, 07:09 PM
  2. TUTORIAL: How to build a 'cheap' 5S-GE motor from 5S-FE
    By bajachris88 in forum Tech and Conversions
    Last Post: 21-07-2010, 09:15 PM
  3. 5sfe crank + 3sge = 5sge?
    By NeoNasty in forum Tech and Conversions
    Last Post: 19-04-2007, 09:18 PM
