Hello,
this is how I do it... may not be the accepted way.
unplug battery
Take out number 1 spark plug (closest to the front of car)
turn over motor using 17mm ( i think ) find the timing mark on the crank pully and mark it with a white marker ( for doing timing later / easier)
Now turn motor over again and when the motor is on it compression stroke and should hear air rushing from the sparkplug hole. At the top of the compression stroke, with the timing mark on 0, you are at TDC.
You can also line up all the timing marks.
Glen
