Results 16 to 17 of 17
Thread: 2jz-gte Oil Pressure Specs
    Default Re: 2jz-gte Oil Pressure Specs
    Remember that some people have their senders for the oil pressure gauge in different spots so this will make the number differ between engines. Once you know it is regular, you just check that it is the same as last time
    QUICKEST 1JZ'S IN OZ
    Just remember that you havent had the motor to operating temperature yet.
    100psi on a motor that has been sitting around idle for ages on the docks and has just started up will probably give a different reading to what you're after.
    The 7psi at idle is once everything has warmed up.
    The 7m recomends no less than 5psi at idle!
  1. 1jz vs 2jz heads
  2. Stuck oil pressure switch 3tg
    By MarioM in forum Tech and Conversions
    Last Post: 11-02-2006, 04:47 PM
  3. 1jz Oil Pressure
    By 1JZ.747 in forum Tech and Conversions
    Last Post: 23-01-2006, 03:32 PM
  4. 3SGTE oil pressure maybe low?
    Last Post: 12-01-2006, 03:40 PM
  5. engine pinging
    Last Post: 15-12-2005, 12:15 PM
