with the oil feed to the turbo youll need a restrictor to about 2mm if the turbo doesnt have one already, is the turbo ball bearing ? i run my feed straight off the engine (i dont use an oil cooler) as long as you get full oil pressure youll be right but id rather tee it off from the motor.
and yeh your right with the return, i use 5/8's hose which is about 16mm, with matching fittings and as high as you can go (you dont want the oil in the sump to prevent flow)
