Results 1 to 6 of 6
Thread: gt28rs turbo=>3sgte st185 modif help
    Jan 2009
    Indonesia
    Default gt28rs turbo=>3sgte st185 modif help
    I just bought the gt28rs turbo for my 3sgte st185 engine.
    Now I need help of what things I need to change in order for the turbo to be able to fit into the engine.
    Kindly advice. Thanks.
    Severely Underqualified Domestic Engineer Fodder's Avatar
    Default Re: gt28rs turbo=>3sgte st185 modif help
    Did you buy just the turbo by itself, or a kit such as offered by http://www.speed-source.net/ ?
    Junior Member Chief Engine Builder Classique71's Avatar
    roundy also has the same turbo on his 185 .. post a note in the gt4 thread or talk to him , he might be able to assist
    Saphira - ST205 Celica GT-FOUR Group A NZ No:1/4
    "Mongrel Garage - back on Aussie soil! "
    Jan 2009
    Indonesia
    Quote Originally Posted by Fodder View Post
    I just bought the turbo itself, without the kit set. Kindly explain why ?
    The kit, from the explanation, includes everything you'll need to do the swap. The bare turbo doesn't. If you look at the kit it mentions it includes adaptor plates to go between the manifold and the turbo, lots of fittings, various other bits and pieces.
    Best bet would be to talk to someone who has done it before as mentioned above.
    If I remember correctly you are changing this to a rear wheel drive setup?
    If so, you would be best with a custom made turbo manifold to suit the rear wheel drive setup.
    You will then need to modify the oil and coolant lines. Plus all the other stuff associated with a turbo swap such as air filter and intercooler pipework and dump pipe etc.
    Joel
    1996 FZJ80 Landcruiser.
    Email : [email protected]
  1. GT28RS on SW20. Pics.
    By jzk25 in forum Tech and Conversions
    Last Post: 10-05-2008, 10:49 AM
