Results 1 to 7 of 7
Thread: True rear sump on JZ variant engines ..
    Apr 2007
    Default True rear sump on JZ variant engines ..
    Does any one know of any one who has built a true Rear Sump configuration including the cast alloy section to suit a 1JZ or 2J engine ? & if so who did it & how much did it cost ...
    Dont think i will be swamped with replies, but fingers crossed ..
    Thanks in advance ..
    Rob ..
    Montrose
    Default Re: True rear sump on JZ variant engines ..
    What are you trying to put it in?
    Why not buy one genuine?
    Apr 2007
    Still weighing things up at the moment, but possibly going to put it in an old 2 door 242 Volvo i have, so its needs to be a true rear sump, not the one that Toyota call a rear sump & its still forward of the rear ..
    So what i need is a rear sump that sits right at the back of the motor, basically like a reversed front sump set up ..
    Rob ..
    Doing it like that creates problems with flexplate to torque convertor bolts, which is why Toyota didn't do it.
    But if you are running a manual, this isn't an issue.
    as far as im aware the closest factory sump you'll get is a mid-rear
    your 3 choices are front, true-mid, and mid-rear
    what do the 4WD JZ sumps look like?
    Apr 2007
    Didnt know they did a 4WD JZ i had heard about a 1UZ 4WD, does anyone know more ?
    Rob ..
    By The Witzl in forum FAQ
