Results 31 to 45 of 63
Thread: TA22: Tie Rod ends/Ball Joints, etc - OEM vs After Market
    Default Re: TA22: Tie Rod ends/Ball Joints, etc - OEM vs After Market
    yeah i made that clearer in my post above Rod.
    Cheers for picking me up on that.
    ...... butt scratcher?!
    Traditionalist Domestic Engineer parrot's Avatar
    I've edited mine too.
    As I said, Of course these catalogues are not always infallible, but may help. Buyer beware blah blah blah. You need to understand that if you go into your parts store, they will sell you whats in the catalogue.
    Cam mountain I feel different from the ordinary
    I added my Post because I know the catelogues are wrong. Not having a Dig at Parrot or Wiztl
    Getting the right parts should not require us to take in a sample but the sad relaity is it does
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Another anomaly which I came across in the 555 catalogue in 2002 (around April, and in Townsville Auto One) was that the idler arm listing was wrong. Unsure if this has been rectified, but it took me a bit to get the right one. TA23 was what the correct item was listed under, incorrect item sent to me turned out to be an RA40 idler arm. List price on the RA40 one was $80, list price on the correct RA23/28 item (note, this does not fit TA22) was $120. Hopefully the listing for the TA22 is right, but make sure it doesn't give the same part number as TA23 first.
    Owen,
    You are correct. The TA23 listing is the corect item for the RA23 and RA28 but not for the TA22. I am led to beleive these are NLA tho now
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    These are the pedders items i'v just received for an ra40.
    1994 GZX90 Mark II 1GZ-FE V12
    All of those will suit the T/RA23/8 except the idler arm. I might look at getting a bracket and shaft made to fit an RA40 idler arm to my RA28 if I can't get a proper idler arm (access to machine shops and fitters makes me smile )
  8. #38
    Another option might be a urethane replacement bush. Fulcrum made these for KE1x idler arms but now out of stock.
    Perhaps available for TA/RA's?
    Just had a look. They list an idler arm bush for an RA40, but not earlier Celica's.
    Their catalogue is not perfect either however. Some errors in their KE1x listings.
  9. #39
    Unfortunately the balljoints on the Celica idlers are prone to flogging out, so just finding bushes will be a temporary solution at best.
  10. #40
    Junior Member Backyard Mechanic egamirrorim's Avatar
    Quote Originally Posted by o_man_ra23 View Post
    This is what my mechanic suggested to after he couldn't find a replacement idler arm. He didn't believe their rarity...
    I guess it's pointless to go down this path then?
    You mentioned in your previous post that have you might get a custom bracket made up, have you gone down that path yet?
  11. #41
    Junior Member Domestic Engineer TA22 GT's Avatar
    I use Triple 5 or 555, they are OEM quality and made in Japan. Never had an issue with them, most good auto shops will have these.
    Simon
  12. #42
    Anyone know of a place in Sydney that stocks these? I've done the ring around to a few places and none had even heard of them...
  13. #43
    Quote Originally Posted by TA22 GT View Post
    Simon
    Simon,
    You cant even buy the 555 TA22 or RA23/8 idler arms in Japan anymore let alone over here.
  14. #44
    Yeah when i was looking they were not available. I was lucky to find an Toyota Genuine item and it hurt the wallet but what do you do
  15. #45
    Junior Member 1st year Apprentice avante's Avatar
    Jun 2006
    Hmmm.
    Bugger.
    I just tried Toyota (who are on the hunt for one), and my local (good, old fashioned!) parts shop.
    Here's hoping...
    They say money talks, all mine ever says is Goodbye
  1. TA22 + rack and pinion
    By "Z" UTE in forum Tech and Conversions
    Last Post: 19-05-2017, 12:02 PM
  2. strut brace for a TA22
    By ca_celica in forum Tech and Conversions
    Last Post: 11-04-2014, 11:55 AM
  3. Ta22 Idler Arm bushes
    By ThaNav in forum Tech and Conversions
    Last Post: 31-01-2009, 01:05 PM
