Results 1 to 6 of 6
Thread: ta22 brake upgrade
    Jul 2009
    south australia
    Default ta22 brake upgrade
    what is the best brake upgrade for ta22???
    Eltham vic
    Default Re: ta22 brake upgrade
    hi toddy
    the quickest and cheapest , probably easiest, is ra 23 struts and rotors
    there is a thread on this here some where .
    someone will find it for you , it may be in the FAQ section
    ian
    The "best" upgrade depends on a lot of factors... What will you be using the car for and what is your budget? These are probably the most important questions...
    For instance i'm in the process of puting RT132 rear discs and AE86 vented fronts on my car. I went the 86 fronts as it will be easier to upgrade again in the future with a wide range of alloy 4spot options. But its not as cheep an initial upgrade as some.
    Jul 2009
    south australia
    (cheap but good) just street got a ca18det in it
    Texas Hold'em Junky Backyard Mechanic fade-e's Avatar
    lol define cheap
    check out my build for an option but i guess i would not consider this cheap
    the final weight of the uprade is exactly the same as the original setup
    unlike the corona/pug/hilux upgrade that ends up weighing more than original
    Forking Architect Grease Monkey
    Jan 2009
    S.A.
    gorex twin pots (same as HX monaro apparently)
    take entire R142 strut assembly
    swap ra23 spring
    profit
    Rotaries are cool...so why are their owners such cocks>>?
    By The Witzl in forum FAQ
  2. Ra40 to Ta22 brake upgrade???
    By Scoobzd in forum Tech and Conversions
    Last Post: 19-08-2008, 10:55 PM
  3. KE55 Brake upgrade Enquiring
    By ke55e1979 in forum Tech and Conversions
    Last Post: 05-06-2007, 09:30 PM
