Results 1 to 12 of 12
Thread: remote oil filter question.
    tasmania
    Default remote oil filter question.
    if you run a remote oil filter setup, does it matter which way you mount it?
    by that i mean, vertical,threaded end to the ground?
    i'm not certain if it would have any effect on oil pressure, that's all.
    beer me!
    south australia
    Default Re: remote oil filter question.
    nah, mounting it the way you said wont matter. plenty of cars have their oil filters mounted that way from factory.
    Bout the biggest annoying thing will be doing oil changes. everytime you loosen the oil filter, the oil runs down and you get your hands all dirty!
    Pressure won't be a problem, its about convenience, where you've got room or how you want to have it for easy clean removal. I know permacool have different port-orientation adaptors. They're not the only option but i've used them and recommend them.
    Check out www.perma-cool.com have a look at the universal kits, and different options for the remote setup. It'll give you an idea, not sure what similar products are offered by others, but i heard good things about these and was happy, would buy them again.
    Can't buy from their website, but www.summitracing.com is my other recommendation for that side of things.
    See also here where i said much the same thing;
    http://www.toymods.net/forums/showthread.php?t=2165
    Toymods Club Member
    tasmania
    thanks guys, yeah the messy changes would be a pain!
    beer me!
    Montrose
    A couple of times, I've managed to bolt them 'right way up' just near the chassis rail right at the bottom = very nice for oil changes. If you have room, do this.
    is the most useless Backyard Mechanic jonchai's Avatar
    may sound silly, but...asking the obvious...unless you change oil very frequently....what is the advantage/purpose of having a remote oil filter install?
    Performance Through Technical Supremacy
    (\__/)
    hehe
    Montrose
    So you can put the filter someplace it will even fit. Sometimes custom exhaust parts etc. get right in the way of where the manufacturer put the filter. If not, you'll still know just why you bought one every time you change the oil on a car with an external wastegate right next to the filter location - it'll soon pay for itself in savings on bandages from 3rd degree burns!
    im prolly gonna have to get one of these for my ra23 powered by a 1ggte. once its all in, its a snug fit. and getting in under the plenum to take out the filter will be a task in itself...
    remotely mounting it somewhere saves u time. makes things a whole lot easier...
    jase
    JZA023
    Tallahassee, FL USofA
    BLING!
    Please make sure of the inlet & outlet- flow direction!
    That old filter you're removing is filtering at its best & doing smaller particles, unless its sludged up from severe service(old lady 15 minutes a day driving, always on cold starte/choke. racing is not a severe condition for a filter), the a new filter will.
    ^^^ i was thinking of the bling factor aswell
    i suppose there is a point made with modified exhaust manifolds in cars that weren't meant to have that particular engine! than again!!!
    (\__/)
    hehe
    theres a few reasons... but mostly ease of access.
    also, if you are fitting an oil cooler anyway, remote mounting the filter makes it a bit easier for the block take off, and easier to use thermostat..
    basically.. it frees up space for manifolds, turbos and superchargers
    further to what stu said - in the case of adding an oil cooler, the other option is to fit a sandwich plate between block and oil filter. Unfortunately for many of us, the space around the oil filter is about a bees dick anyway, so the sandwich plate just makes things even harder/impossible - hence the relocation.
    plus once you gotta pay for a sandwich plate, it's not much more expensive to get it remote mounted
  1. Oil Filter Interchangability
    By 3sgte in forum Tech and Conversions
    Last Post: 13-03-2006, 11:35 PM
  2. afm and pod filter....
    By mrxplode in forum Tech and Conversions
    Last Post: 16-02-2006, 04:21 PM
  3. 2s-c oil filter assembly tread size?
    By sam-131 in forum Tech and Conversions
    Last Post: 27-01-2006, 01:24 AM
  4. Full flow Oil filter relocation line thickness
    Last Post: 02-01-2006, 05:21 PM
