Results 1 to 11 of 11
Thread: T series diff ratio
    Apr 2009
    south australia
    Default T series diff ratio
    Hi all, my RT132 corona 'manual' is fitted with a T series diff from factory. Ive been trying to find information on the ratio's of the diff and was wondering if i have a 3:9 ratio? Did the auto ones come with 4:11? Reason i am asking is the backlash in m diff is pretty damn bad and the seals are starting to leak so im basicly looking for a replacement.I was considering using the LSD ones from the AE86 but dont know if i have to mod my diveline to fit it. What can i do with my problem?
    Front Yard and Backyard Mechanic white_sandshoe's Avatar
    Jun 2009
    Default Re: T series diff ratio
    http://akb.norbie.net/Public/AxleCode.aspx
    have a look on your compliance plate next to where it says Trans/Axle
    there should be a code next to it that says something along the lines of T312 or T292
    Punch that code into the translator in the above link, and rock and roll!
    I'd suspect it's likely to be a T312, making it a 3.9:1, but could be anywhere from a T302 (3.73:1) to a T292 (4.1:1)
    "Think of it like customer service, but the customer is *not* always right. And, you'd rather not have their repeat business." - Mullett
    "well I don't know what the world may need, but a V8 engine is a good start for me..."
    Apr 2009
    south australia
    checked my car just then, its says T312 so it was 3:9. So if i go to the wreakers and find a auto one, would the ratios be 4:11?
    toyota didn't always change it's diff ratios between auto and manual. go to the wreckers and find a toyota with t292 on the plate in the same place your corona had t312 written. ta22, ta23, ra23, ra28, ra40 celicas all had the 4.1:1 (t292) centre that you want
    Look for an auto RA40... I always find a t292 in these and they are plentiful at wreckers
    Apr 2009
    south australia
    does anyone have any experience with a 3t-gte -w55 box using 4:11 diff? what revs does it hold at 100kmph?
    Rather than hijack, I had a similar question.
    Are crown and pinions interchangable between same sized diffs - can you mix and match? e.g. say you had a 41 / 9 (4.5), can you just get a 43 crown gear and use it with the 9 tooth pinion on the 4.5? Or are CP paired and you can swap different gears to make combos?
    Basher Grease Monkey
    Feb 2007
    Crown wheels and Pinions are paired and won't work when mixed and matched.
    Scott
    coronacoronacoronacorona
    Quote Originally Posted by thanhngo View Post
    To add to what Scott has said. For a given diameter diff housing only a certain diameter crown wheel will fit. If you want more teeth on the crown wheel you have to decrease the tooth size, that then changes the size and pitch of the teeth on the pinion. Meshing different CW and P's would be like fitting a Metric bolt with an Imperial nut! The other reason for not trying to swap them even when swapping like for like, is that the CW and P are lapped together at the factory to ensure best mesh. Then of course you have the black art (Shims and Prussian Blue) of getting the mesh correct when you actually install the set into the housing.
    cheers Chuck.
    MS51Crown Coupe,
    Hehe that's a month & a day off the sixth anniversary of the death of this thread Chuck...
    I'll take a punt this topic was showing under Justens t-series for sale thread?
    Jason
    stunt dog Backyard Mechanic Esteban's Avatar
    wa
    Hahaha search necromance win!
  1. Hilux G series Diff Conversion
    By auto351 in forum Tech and Conversions
    Last Post: 23-02-2008, 04:51 PM
  2. G series diff flange on F series diff?
    By antag in forum Tech and Conversions
    Last Post: 14-12-2007, 02:53 PM
  3. s series diff info needed
    By styler in forum Tech and Conversions
    Last Post: 04-12-2006, 02:40 PM
  4. changing the gear ratio's in hilux diff.
