Gen = ? Alternator?
The starter should be simple, will have a thick power cable that goes to battery and another thin wire to switch the relay which comes from the key barrel.
Alternator will be similar, a thick power cable runs across to the fuse box/battery, and there's another 3 pin plug which may need to be changed/repinned to suit the 1uz alternator or extended if it's on the wrong side.
Are they the only things you're you're having trouble with?
