Results 16 to 30 of 39
Thread: cressida coilovers
    Forum Member Backyard Mechanic
    Jan 2011
    Default Re: cressida coilovers
    ive been serching the japan yahoo and jauce and they only offer jic for close to 2700 new so 3000 landed in aus
    there serial nine ones are made for cressidas and cressidas only and tested as well
    they offer awsome rearsub frame locks as well but i would avise to brace up your subframe for those mods
    they also offer awsome rca for more low
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    when comparing prices and quality tho
    Serial9 are megan coilovers , which have very little use in aus and are on the otherside of the world if something go wrong and about $2k delivered (shipping, import tax etc)
    JIC are pretty well known for leaking and knocking etc at low use and generallly hating aus roads
    BC are locally sold and supported, rebuildable in aus custom spring rates etc
    you could have them within a week welding should only cost $200 at the most
    plus they are only $1500 for top of the range standards are only $1200
    plus see if you can find a bad thing said about them?
    one of my bc front inserts was dead straight out of the box, had it replaced and all is good. Much happier with the BC's compared to the two sets of x81 JIC's I've had on past cars.
    For the fronts you cut the front struts so 50mm of the original tube protrudes, then clean the stub axle up and weld the base sleeve on. I added two rosebud welds to each of mine about 35mm up the tube in addition to the base weld
    Jan 2011
    yeah right didnt know the serial nine coilovers where megan
    ive had a few sets of jic and i agree good quality but fail easily
    so bc are from just jap yeah u may have swayed me in favor
    but how did you go with alinment for the welding or does it all find its spot fairly easy
    Jan 2011
    when u say u can pick spring rate how fexable is that option
    what spring rates have peps chosen
    if i could i would think something like 8front and 6 rear or 10 front 8 rear but rate have u guys used
    Jan 2011
    does tein have any (new)options available
    May 2007
    tasmania
    simply email just jap and they will do the spring rates you want
    Jan 2011
    yeah ive emailed em think the top of the line ones are only 1299
    think front 12 and 8 rear is abit unbalanced for my liking but yeah if they offer all sorts i may just buy a set myself
    as you guys said for value for money they sound pretty good and if they dont do seals like the jic thats even better
    as anyone used rca with these?
    Megan MR-CDK-MX83 = rebadged BC V1
    from respective sites
    Megan
    Spring
    . F: 62mm ID; 180mm length; 12 kg/mm
    - R: 62mm ID; 200mm length; 8 kg/mm
    - Cylinder
    - F: 110mm stroke; 250mm length; M2 valving code
    - R: 115mm stroke; 240mm length; A12 valving code
    BC V1
    Spring
    - Front Rear
    - 62-180-12 62-200-8
    - Cylinder
    - 250-110 M2 240-115 A12
    May 2007
    tasmania
    interesting greybeard,
    megan have been around alot longer than bc tho
    Jan 2011
    thats is interesting
    Apr 2008
    i had 12-8 jic's and they felt soft but fair balanced...i just ordered 13-9 and the also have 30 point damper adjuster
    Jan 2011
    12s are far from soft imo but it may have worked for you
    10f and 8 r worked well for me but if i can get em lower i will they still havent got back to me yet so ill see what they can do
    Apr 2008
    well i guess its all depending on use...
    Jan 2011
    yes it would work well for drift
    but i want mine to be an allrounder street, drag, drift
  1. a70 supra coilovers
    By gttwinturbo in forum Tech and Conversions
    Last Post: 15-11-2008, 09:28 PM
