Results 1 to 11 of 11
Thread: 82 hilux v8 conversion
    Feb 2011
    Default 82 hilux v8 conversion
    i have a 82 hilux single cab and im in the process of converting it to a 304 holden v8 with trimatic gearbox. just wondering if anyone has done this and any info on conversion kit, brake upgrades or anything would be good..
    2WD HILUX
    Jul 2008
    Jan 2008
    queensland
    Default Re: 82 hilux v8 conversion
    Why not keep it all Toyota and fit a Lexus V8, maybe cheaper unless you had the Holden 5ltr layin around, the old 5ltrs are quite heavy and the turbo 350 box is large unit, is yours a 4x4 or 2wd? If the brakes are similar to the later RNseries then the Skyline 4spot calipers are fairly straight forward to fit with 300mm BA Falcon rotors, You can use 15inch falcon wheels as a cheap alternative to mags.
    Jul 2008
    by the sounds of it he's already got the driveline, at a guess i'll say vk or vl commo with quadrajet carb and (as stated) trimatic auto trans
    the good news with these motors is that the sump and pickup are interchangable with the earlier hq to wb v8's
    moving the hump to the rear if needed.
    Jan 2008
    queensland
    Sorry dude got mixed up with some of the above mentioned threads, still old heavy cast iron engine, I'm a Holden man thru and thru but the old 5ltr wouldn't be my first choice, just my 2cents.
    Feb 2011
    thanks for the info.. pretty helpful!! yer i can get this motor at the right price so i think i will stick with this motor. there is not much info for the early hiluxs (82) usually start around 83 and 84 are these models similar??
    Jan 2008
    queensland
    Whichever V8 you choose ya gonna have clearance issues in the exhaust department,you will also be gettin tight for spark plug changes too, don't know about the Holden V8 but you may have trouble with drivers side tappet cover on the brake booster aswell, Hilux's are shit for places to mount the ECU in the cabin area if you got A/C, don't think they are to similar to the later models chassis wise.
    My 86 Hilux has a mildly tweaked 308 and a TH400...all seems to fit fine (i didn't do the conversion)....that driveline is up for sale if it's of any interest? You'd get the mounts and the modded sump, tailshaft B&M shifter etc??
    ive done and helped with some holden v8 convertions into 4x4 hiluxs
    there not the best fit but they fit in there, dizzy can be hard to get to being so close to the firewall, and radiator to motor clearance has been tight.
    depends on were u sit the motor to what will be more of an issue, i cant remember what models the cabs were but some fitted better than others
    id look at a lighter motor if it was me
    but holden v8s are cheap as lol
    dan.
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
    spank that naughty.. Grease Monkey
    Aug 2010
    country Victoria
    loose the fuel pump and go electric,lower engine ,better .
    concentrate on your tailshaft angles to avoid vibration
    82 is a good year as the pollution and noise limits are more generous ( depending what state you live in
    good luck
    Remember this is a recreational activity ......
    we got toys ! 83 lo lux in matte black..... amazingly 18 rg powered , one day it will run right !
    the dinosour 90 gsx r 750 with ohlins and yoshi , and the dirty little secret 125 vespa ,4 speed and kick start
    Feb 2011
    @justenGT8
    i tried to send u a msg but idno if it worked.. how much ? where is it located ? what does it include? and what internals does engine have?
    thanks
  1. 1998 ln 167 hilux diff conversion, need help on ratios please...
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 03-08-2010, 09:14 PM
  2. Replies: 8
    Last Post: 07-05-2009, 12:45 PM
  3. Rn110 hilux 1GGZE conversion
    By Bullfrog in forum Engine & Driveline Conversions
    Last Post: 15-02-2009, 08:17 PM
  4. MA70 --> JZA70 Conversion
  5. Clarification of Technical FAQ and Conversion Threads
    By river in forum Toymods Car Club Membership and Feedback
    Last Post: 05-06-2006, 09:20 AM
