Results 1 to 9 of 9
Thread: Intercooler piping on 3TGTE
    Apr 2009
    south australia
    Default Intercooler piping on 3TGTE
    I future i will be installing a front mount on my car.What is the best size cooler,piping and design for it?. I was think of running 2.25 piping with a mid size cooling pro intercooler.
    Texas Hold'em Junky Backyard Mechanic fade-e's Avatar
    Default Re: Intercooler piping on 3TGTE
    alot of people run the piping along the fron bar bracket so any size will work as long as you cut enough out to fit it in...
    when determining size, you need to look more at the power your car/motor produces rather than what will fit as there is no point having a 3" IC pipe for a stock motor
    but 2.25 is fine for stock motor with low to med boost...
    actually did w write up but cant find it.
    The same info can be forn on my build up thread
    http://www.toymods.net/forums/showth...ght=riceburnas
    Pages, 5,6,15 and 28 have pics and info.
    Nath
    -Just Alloy Radiators-
    www.alloyradiators.com.au
    Junior Member Domestic Engineer TA22 GT's Avatar
    I made my owm intercooler piping using 2 inch stainless steel tube.
    Some info I put together ages ago, http://users.chariot.net.au/~stmezz/interc.htm
    My 3T GTE currently has 145rwkw at 14 psi using only 2 inch tube with stock TB and plenum. A lot of air is gonna go down a 2 inch tube, I think you'll find that other areas of your engine will be causing more restriction, eg stock plenum or exhaust manifold....
    I do have plans to fit a custom intake manifold (that I have already made but havent found time to fit), still only planning to use 2 inch tube for the intercooler piping as I feel this is big enough....Aiming for 200rwkw...
    Hope this helps,
    Simon
    Apr 2009
    south australia
    nice work mate, i was thinking of getting stainless aswell but its gonna cost alot.
    Gday mate,
    I suggest researching what intercooler you will be running, then determine what size piping will be suitable.
    From memory 2.5" inlet was pretty common when I purchased mine, so that's the diameter pipe I went.
    See some pics of my car in the members section here.
    Rob
    See my 3T-GTE powered TA22:
    Click Here
    Currently running 192.8rwkw @ 20PSI
    Junior Member Domestic Engineer Hurricane's Avatar
    im runing 2 1/2'' piping on my 3t-te in my ke20 can't think of my cooler size? it also 2 1/2'' 200x450 maybe? seems to work ok.
    dan.
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
    Apr 2009
    south australia
    How much more lag is there? and anyone got pics of their piping work?
    mine with a skyline T3 turbo hits boost around 2800rpm, no pics yet.
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
  1. Intercooler piping - MZ20
    By ra65 in forum Tech and Conversions
    Last Post: 08-09-2007, 12:15 PM
  2. Intercooler piping...protecting from heat?
    By deviant in forum Tech and Conversions
    Last Post: 02-02-2007, 07:21 PM
  3. What Size Exhaust and Intercooler Piping Sizes??
    Last Post: 17-04-2006, 07:04 PM
