Page 3 of 3 FirstFirst 123
Results 31 to 42 of 42
Thread: Car Batteries and Relocation Kit's Q&A
    Chiba
    Default Re: Car Batteries and Relocation Kit's Q&A
    I used 0 gauge cable in my Levin. My starter pulls a measured 250A on cold start, so I went with the biggest cable to make sure I won't have a problem. 2 years on and it's fine.
    Also, where in Queensland are you? If you can get down to Brisbane Southside, I can crimp your cables properly for you. Being an electrician, I have access to a crimper that will do up to 120mm^2 cable... (that's 0000 gauge cable )
    Crimper:
    Crimped Lugs:
    (Ignore the ocky strap. A custom alloy box is in the works...)
    Slanted Photographer Automotive Encyclopaedia LeaThaL's Avatar
    Aug 2006
    thanks for the input fellas,
    TERRA, im on the northside up sunny coast almost but i do make random trips over that way so when i do i might take advantage of your offer and check your setup, cheers!
    and TAKAI, yeah ill prob run another wire soon enought as i do want the car to be nicely juiced up, another 90 down the pisser but it will be worth it after all the money ive spent on this thing so far, i could of bought a thiner dry cell battery but atleast the battery is filling the spot where the old computer use to sit in the boot
    MWP, i was very curious as to if i could run a seperate wire to power the fuse box and the starter as i ran the wire i have now straight to the started and just soldered and taped the fuse in using a spare piece of wire i had left from the alternator power extension, im starting to think thats even too small
    thanks again fellas
    1 G L O V E
    88 Ga70 supra --- Under powered and over cooled Daily
    Chiba
    No worries, just shoot us a message a few days before the next time you're down, and I'll be sure to grab the crimper.
    Tasmania
    could you run say 0 guage direct from your battery to the starter, then 4 guage from the starter to the fuse box? or would the draw on start up fuck up the power that you want at the fuses?
    1973 TA22
    Chiba
    As long as the 4 gauge is thick enough for the power draw for the rest of the car, it will work the same as if it went to the fuse box then to the starter.
    Tasmania
    yeah i was just thinking thats an option insted of running two cables the legnth of the car
    1973 TA22
    Quote Originally Posted by Cuts
    could you run say 0 gauge direct from your battery to the starter, then 4 guage from the starter to the fuse box? or would the draw on start up fuck up the power that you want at the fuses?
    Yeah you could.
    I ran welding cable from the battery to the engine bay, then split that into two 4 gauge cables. One to the fuse box, the other to the starter.
    It works fine.
    Using two cables like mentioned above is the better way of doing it.
    I didnt do it that way as i already had a length of welding cable ready to be used.
    My battery box with Jaycar 100A breaker and cutoff switch:
    Welding cable to two 4 gauge cables connection in the engine bay:
  8. #38
    Aug 2006
    yeah i think next pay i pay invest in a 2nd wire, that way i have 500amps to share around prob a good thing too if i get a 100amp breaker just incase the one up front doesnt do the job
    ive used what i think is around 6-7 gauge wire to go from alternator to the orignal point, will that cope or had once again, a "professional" fucked me around?
    1 G L O V E
  9. #39
    Chiba
    Well 2 gauge is rated at 225 amps, and the starter on my 4AGZE pulls that, so I would say yea, yours is too small.....
    http://www.the12volt.com/wiring/recwirsz.asp
  10. #40
    Make sure you do install a breaker/fuse at the battery.
    You have to think about what would happen if the cable wore through and touched the body somewhere.
    A breaker/fuse will stop your car going up in flames.
  11. #41
    Aug 2006
    what did that breaker set ya back? and what it looks im going to do is just buy anyother 4 gauge like what i have now and just run it straight down as you mentioned so i have the 2 deicated lines, and im going to replace all my earths with better ones and then i will have piece of mind that its all good
    thanks again for all the dudes that have given input!
    1 G L O V E
  12. #42
