Results 1 to 6 of 6
Thread: RA23 Rev Gauge Bouncing Up and Down
    Why am i always a.. Domestic Engineer RAAAH23's Avatar
    Jul 2009
    New South Wales
    Default RA23 Rev Gauge Bouncing Up and Down
    Hi everyone
    i have a slight problem, its on and off and doesnt really worry me but just wanted to see if someone else has run into this problem.
    ok so when it happens ill be holding the throttle down at a certain postion and hold the same rpm as i do this the gauge will fluctuate by +/- 1000 rpm and even more if the aircon fan or lighter is on.
    my uncle whos got an old mkII suggested its the connection either at the alternator or at the reg box. i have checked all the connections in that area and cleaned them with contact cleaner but still the problem persists
    your thoughts are greatly appreciated
    ~ Alex
    Cheers, Alex
    - 1976 TA23 2T-GTE GT3076 ID1000cc E85 Haltech PS1000, W58, G Series Diff, B45 Simmons
    Jul 2009
    New South Wales
    Default Re: RA23 Rev Gauge Bouncing Up and Down
    anyone got an idea at least? oh one more thing will this affect my rego inspection? its up at the start of august
    Cheers, Alex
    Original Trendsetter Chief Engine Builder Harreh's Avatar
    Jul 2008
    Definately sounds like an issue with the signal but thats really not something I can help with.
    It certainly wont affect your rego though, tacho isnt a requirement for the check, a lot of cars dont even have them.
    Perhaps it could be an issue with charge or something to do with the alternator if it gets worse as the power draw changes, I'm really clutching at straws here
    AW11 Turbo build
    1UZ Soarer Turbo build
    Imitation is the most sincere form of flattery
    Jul 2009
    New South Wales
    thanks for your info aslong as it wont affect rego i dont really mind jst puzzled
    i dont look at the thing anyway
    Cheers, Alex
    Nov 2007
    Might be the ground connection for the instruments. Especially if running extra accessories increases the effect. Not sure where the ground is in a 23 though. Most likely behind the dash on some part of the metal frame.
    Glen
    RA28 (18RG)Members Ride
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
    Jul 2009
    New South Wales
    hmm i see i didnt check that. i can see why that would most likely be the problem because it happens when you hit a bump/pot hole and stops after you hit another one so maybe its dilogging it and then putting in back in place.
    thanks ill try that out
    +rep for both of your guys, thanks
    Cheers, Alex
