Results 16 to 30 of 31
Thread: Doing a manual rack conversion in AE86
    Jul 2008
    Christchurch
    Default Re: Doing a manual rack conversion in AE86
    Matt, let me know how you go about your manual conversion if you go that way... Im picking AW11 rack, AE86 tie rods, and A70 intermediate shaft. See you on the track! (at the end of the year hopefully lol)
    Texas,USA
    This is for LHD but you get the idea and info.
    http://forums.club4ag.com/zerothread?id=15662
    ae-86 (levin) footwork
    TE-71 w/1uzfe
    Autronics SM4
    Jul 2008
    Christchurch
    Thanks Turbotoy, So basically AW11 rack, lots out there, get some tie rods for AE86, have them but will probably buy new ones, and MK3 Supra intermediate shaft and we are rolling.
    Matt if I get these parts for my conversion you are welcome to any PS parts I have laying around...
    Jul 2008
    Christchurch
    Incidentally, does anyone know if you get the KE70 manual rack, the same parts are needed? As in AE86 tie rods and MK3 intermediate shaft?
    Texas,USA
    Funny thing is I am doing this conversion as we type. I have a t-18 in the garage and I am using an ae71 column, engine crossmember (W/3tgte engine mounts welded on), and ae71 rack and pinion. ae86 inner and outer tie rod ends and prothane urethane bushings.
    TE-71 w/1uzfe
    Autronics SM4
    perth
    when i put my e7 rack in i had to swap the lower uni joint as well as one of them was longer.
    Jul 2008
    Christchurch
    Ok found a KE70 manual rack, can anyone confirm this is the same scenario as the AW11 rack conversion? use AE86 tie rods and supra intermediate rod?
    Jul 2008
    Christchurch
    Can anyone confirm if the u joints on the PS and manual rack are the same?
    Forum Sponsor Conversion King
    The spline is the same, its only the larger toyotas that went to a different spline size.
    Not sure if the lengths are the same but i would assume so.
    Texas,USA
    Quote Originally Posted by 4000GT
    It says they are different sizes on that link I posted. So the u joints are not interchangeable.
    TE-71 w/1uzfe
    Autronics SM4
    Jul 2008
    Christchurch
    Ah ok, thanks mate. Looks like you either do the MR2 conversion, or use AE86 parts...
    New Zealand
    You can't seriously be having problems finding KE70 bits in Christchurch????
    Post a wanted ad on Club K (http://www.club-k.co.nz/Forums/forumdisplay.php?fid=15) and there is bound to someone local able to help you out with all the parts you need.
    Callum
    Jul 2008
    Christchurch
    haha yeah there are a few here the ones so far have been steering box not rack. But found the rack now up north, just need to work out what intermediate rod is needed, and if the 86 tie rods are needed for it too.
    New Zealand
    I will have a spare KE70 lower shaft but not for a few months as I need it to check motor clearance in a dummy shell I am using. My advice though is grab everything from one car, sedans tend to have racks more than wagons so start there although a slant front wagon is pretty certain to be rack and there are a lot of those rusting away.
    Callum
    Jul 2008
    Christchurch
    Thanks for the advice, I have almost bought a KE70 manual rack with U joint, So I just need to find a Supra or similar intermetiate rod, Or get mine extended or machine up a new one.
  1. RA28 stering rack conversion (need advice)
    By bullitt in forum Tech and Conversions
    Last Post: 20-08-2014, 10:37 AM
  2. RA23 Auto to Manual Conversion
    By Night Rider-TA23 in forum Tech and Conversions
    Last Post: 18-10-2007, 07:23 AM
  3. Upcoming manual conversion. quick question
    By uncivilised in forum Tech and Conversions
    Last Post: 12-09-2007, 04:04 PM
  4. AE86 : 4AC -> 4AGE conversion on a budget
    By li21 in forum Tech and Conversions
    Last Post: 09-06-2007, 01:12 AM
