Results 1 to 8 of 8
Thread: man conversion 1ggte
    May 2009
    Default man conversion 1ggte
    i have a gen3 are all the flywheels the same or do i need to track down a gen3 one?? and any one know a good place to try find a bell housing around newcastle or even better is there conversion kits out there been to a few jap wreckers and no go
    thanks
    scrap the question on the flywheel just found it
    Nov 2007
    Default Re: man conversion 1ggte
    All the flywheels should be the same, only differences between the gens were the turbochargers, injectors and wastegates.
    Buy my j160 6 speed box+clutch+pressure plate
    RA23 - Twincharged
    JZZ20 - Daily
    The old One Backyard Mechanic
    If Irecall corectly the gen 1 nad 2 had 9 inch flywheels and the gen 3 had a 9.5 inch flywheel. You can use the 9 inch on a gen 3 as long as you have the matching clutch and cover plate.
    Craig
    May 2009
    Quote Originally Posted by Kedderz
    j160 6 speed box+clutch+pressure plate (flywheel and belhousing)?? lol
    whats the size difference of the 6 speed to the w58 5speed rola tunnel isnt very big lol
    May 2009
    Quote Originally Posted by ddeane
    Craig
    would this make a difference with started motors to?
    The measurements quoted are for the clutch face only, the physical dimensions are the same if not quite similar and at least in regard to the starter motor, they are the same (remember, you are talking about the same block and transmission between Gen 1/2 and Gen 3 so there is no reason for them to be different).
    The point he was making is that id didnt matter what version you have, that as long as the flywheel matches the clutch you will be sweet.
    There are also a few photos floating around for the J160, some in particular show them compared to a W58 and a T50 gearbox. IIRC it wasnt that much bigger, the main differences were that the bellhousing and starter motor bulge were bigger and that the shifter is obviously much further back. Use those terms in a search (try google too as 3 character terms arent serchable unless they are popular so you might get luck on the others)
    The j160 fitted in my ra23 wihtout massaging the tranny tunnel and it orginally came with a w50!
    The j160 comes with a bellhousing yes, clutch + pressure plate but no flywheel sorry.
    RA23 - Twincharged
    JZZ20 - Daily
  1. MA70 --> JZA70 Conversion
