Results 1 to 15 of 16
Thread: 4K dies then comes back to life again!?!
    Junior Member Grease Monkey supra_cam's Avatar
    tasmania
    Question 4K dies then comes back to life again!?!
    I was driving my KE70 along the highway and all of a sudden it looses speed and comes to a complete stop. I restarted it a few times and it would cut out after about 1 second. I called my brother to come and have a look and when he turns up about 20 minutes later, it starts first time and drives completely normal. Anyone know what might have happened?
    Junior Member Grease Monkey 78Rolla's Avatar
    Default Re: 4K dies then comes back to life again!?!
    Just a guess - but maybe something was loose, or became loose when it heated up on the highway, 20min later its cooled down and works fine??? dunno...but 4k's can't have too much go wrong with them!
    The yellow beast - ke30 beams
    Project swap over - '74 ke30 2dr
    Apr 2009
    south australia
    Did the electrics cut out? if so it could of been a loose ground wire or air,sludge in fuel lines
    vic
    Ballest resistor will be burnt out id guess.
    Dave
    tasmania
    The electrics didnt cut out, maybe something in the fuel lines, i'll have another look tomorrow.
    corollamanic Backyard Mechanic
    May 2006
    your car is JESUS
    or it's a vampire ... you need to wave a wooden stake or cross at it and see if problem re-occurs.
    or you have a fuel-related problem?
    New Zealand
    Cold weather at high speed? If so could have iced up the carb. Is your aircleaner set to winter or summer?
    Callum
    Tasmania
    Try replacing the fuel filter.
    Cheers Brett.
    tasmania
    Well it got kinda worse today, it will only drive when the I hold the key in the start position in the ignition, if I let go the car slows down and turns off after a few seconds. All I need is for the rolla to get me about till the 20th of July when I fly off to europe for 2 years!
    New Zealand
    Running on key sounds like ballast resistor as said by Cambelt, know anyone you can do a quick swap with to test?
    Callum
    Quote Originally Posted by supra_cam
    If your car 'runs' properly while it is in the start position, It is your ballast resistor on your coil, no doubt about it.
    Check connections. If they seem ok, replace it. It's a $8< part.
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Javal's got it. The ballast is bypassed during starting. So it works while on start, then when it goes back to using the ballast circuit, no power to coil, no spark.
    tasmania
    thanks for the quick response guys! will replace it tomorrow.
    tasmania
    Had a look at the ballast resistor, one of the wires had come off. Put it back on and problem solved. I can now drive with two hands on the wheel again, thanks guys!
  1. back seat modification
    By Born-Enthusiast in forum Tech and Conversions
    Last Post: 01-06-2007, 11:43 AM
