Results 1 to 8 of 8
Thread: 4age electrical issue
    Junior Member 1st year Apprentice pen15's Avatar
    Jun 2008
    Default 4age electrical issue
    hey all you tech guru's i have a little issue with a 4age i have been helping my friend build
    problem: when i turn the key to engine ready phase (reds) all is normal i have power at the coil and ecu has power i then turn the key to start the engine turns over nicely it fires and then we get ignition as that happens i leg go of the key back to reds for the car to run then the engine will run for only a moment before stalling i have run a test light on the fuel pumps and they turn off when the key is let go from the start phase what would be the cause for the fuel pumps to turn off
    i have noted that the engine open close relay will click when i turn the key to start the car and then click again when i let go of the key to let the car run ( aka stall)
    would this be an issue with the wiring in the engine open close relay?
    cheers all
    mat
    (note i have done a search google on this forum and on others an not the exact problem i am facing help would be great as i am stumped)
    Default Re: 4age electrical issue
    By engine open close relay do you mean the Circuit Opening Relay? Sounds exactly like that relay isn't working properly, it should latch open after ignition to keep the pump running after the engine has started
    Jun 2008
    Circuit Opening Relay thank you my mistake well you think this could be caused by a faulty relay i will try another relay as i have 1 spare
    Victoria, Mt Macedon
    Just check the COR is connected properly too. It should have two triggers, one from the key in the start position, and the second either from the AFM (if it has one) or the ECU (FC pin on the 4As I've seen).
    There's an article about CORs on here called "your friend the circuit opening relay" or something similar. May help with wiring, if that's to blame.
    Hen
    Jun 2008
    ok i have a pinout diag and for some reason 1 of the wires that holds the relay closed after the ignition stage is done is hooked upto the stop lamp is this correct?
    Breaker of all things aka Backyard Mechanic Chrisso's Avatar
    Vancouver, BC
    As Hen said, the FC pin from the ECU holds it on. This link gives a nice clear picture and notes. This is what I used when doing mine.
    http://www.rollaclub.com/faq/index.p...g_Relay_Wiring
    AE86 4 shades of silver - The Lone Ranger's steed is on the road again!
    AE86 shell - waiting for a donor car from the auctions.
    Jun 2006
    Tasmania
    the pin puts out a negative signal, check it with a test light, get a mate to try start it, see if light stays on, if it does its a relay problem, if it goes out thats why your circuit open relay isnt staying on. Prob ECU issue
    Jun 2008
    found problem the pin on the ecu wasn't pushed all the way in was a bees whisker from making contact all sorted thanks all for the help
  1. Replies: 4
    Last Post: 13-03-2007, 10:44 AM
  2. 4AGE "Heavy Duty" Clutch issue
    By Talasas in forum Tech and Conversions
    Last Post: 12-02-2007, 10:39 AM
  3. 4AGE 86KW TVIS V 100KW 4AGE + Shocks
    By GeeEss in forum Tech and Conversions
    Last Post: 17-01-2007, 08:51 PM
  4. 4age engine mounts
    By duff_boy in forum Tech and Conversions
    Last Post: 03-03-2006, 12:35 AM
