Results 16 to 30 of 34
Thread: 3t-gte Running Wayyyyyyyyyyy To Rich?
    Jun 2009
    victoria
    Default Re: 3t-gte Running Wayyyyyyyyyyy To Rich?
    mate..... start at the basics, is it black or blue smoke? if black, check ur fuel pressure first. if u got 250kpa or 2.5 bar.... pressure is good and possible a/f meter, is the gt4 jap spec?
    mine is and it is factory tuned to 101oc.
    Aus is 95oc
    If prob is still there poss ecu prob
    i have just had that prob and changed my a/f and still tooo rich
    i am now installing an emanage blue...
    apparently gt4 ecu r common to break down over 10psi,
    Apr 2009
    south australia
    engine came out of a TA63 celica
    Jun 2009
    victoria
    oops i thought 3sgte. is it carb or inj?
    Apr 2009
    south australia
    fuel injected
    Jun 2009
    victoria
    does it run rich cold.... all the time?
    has it got 1 wire switch or 2?
    Does the gauge work?
    i guess im asking do they run 2 switches? temp and sender or both together as 1?
    if single wire it is sender to dash.
    sorry i am unfamiliar with them what vehicle have u got and is the motor from?
    Jun 2009
    victoria
    can u extract codes from the ecu?
    Apr 2009
    south australia
    car was wired up at a workshop "fours n more" or something about 10years ago, temp gauge was working fine before. How do u get these codes?
    Jun 2009
    victoria
    i can find out tomoz if i know what car madel etc...
    look at the thermostat housing for the switch and see how many wires.
    does the gauge work now?
    Apr 2009
    south australia
    celica 1800gt-t 1884 (ta63) is what the engine came out from and has been in my rt132 corona for over ten years running fine till now
    These ecu don't have codes, its basically a nipondenso ljet system. It could be because the engine is running very cold, check your thermostat. Also check your cold start injector is not running the whole time, discontect the wires to it for a start and see if things improve. You will need to check your fuel pressure and also check to see if the air flow meter has been buggered with.
    Roger
    Apr 2009
    south australia
    checked my car today, pull of the hose on top of the FPR on the back of the fuel rail and there was strong smell of fuel, im gessing the FPR is split, where can i get a replacement?
    shit... i think the old 3TGTE fpr is pretty unique to the old-style toyota EFI engines....
    might be easier to put on an aftermarket FPR?
    try a sv11 camry, or any euro ljet car such as fiat, volvo, saab etc. Not sure how these go with positive pressure
    roger
    Quote Originally Posted by el corona
    Test it before you go replacing it.
    I'd also try unplugging the cold-start injector and see if that fixes your problem.
    Here are the main sensors which feed to your ECU that will affect your fuel economy
    -Air Flow Meter
    -Coolant temp sensor (gives the ECU it's temp signal so it knows when to turn the cold start injector on and off)
    - 02 Sensor (tells the ECU how good the air/fuel ratio is, in a roundabout way)
    The fuel pressure regulator could also be a cause of your troubles, but like i say, test it before replacing.
    Apr 2009
    south australia
    where is the "cold-start injector " located in the engine bay?
  1. 1g-gte running rich and bad idle
    By Z2TT in forum Tech and Conversions
    Last Post: 16-10-2008, 03:13 AM
  2. Will running rich screw up a new engine?
    By tooch in forum Tech and Conversions
    Last Post: 12-05-2006, 06:32 PM
  3. 4age running uber rich
    Last Post: 30-04-2006, 06:27 PM
  4. Running in a motor. opinions?
    By Aust162 in forum Tech and Conversions
    Last Post: 27-02-2006, 08:19 PM
