Results 1 to 3 of 3
Thread: 2tg valves
    May 2006
    Selangor
    Default 2tg valves
    I've got a set of stainless steel valves of unknown make which has the same stem diameter as the stock 2tg valves but with a bigger valve face diameter. Would like to know if it's ok for me to machine down the the face without problems? Would i lose it's hardness properties and suffer premature failure?
    Default Re: 2tg valves
    Machining down valve size is usually only ever an issue with titanium valves because of a protective coating that have on the valve head. I have machined down a few sets of stainless valves with no ill effects. If it is a ordinary conventional stainless valve you will have no problems.
    But, why dont you get the valve seats cut to suit the larger valves? Is the stem length the same as a 2tg?
    May 2006
    Selangor
    thats what I've in mind but I still need to machine them down a little coz the valve face is thicker than the stock ones.
    stem length is longer but I think I can get the machinist to shorten them and cut the same groove for the valve locks. Also I see that the stock 2tg intake valves are non stainless steel, would it be ok to change those to these machined downed stainless valves as well?
  1. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 06:27 PM
  2. 2tg and 3tc bearings interchangable
    By styler in forum Tech and Conversions
    Last Post: 18-05-2007, 07:49 AM
  3. 2TG head onto 3TC block...need help
    By quikestsilva in forum Tech and Conversions
    Last Post: 15-05-2007, 08:07 PM
  4. 2tgue & 3tgtue info
    By chippa07 in forum Tech and Conversions
    Last Post: 06-01-2007, 07:29 PM
