If the speedo is like the MX73 you'll see 2 screw near the centre at the very rear (where the speedo cable plugs in). One of these will go to earth, the other will go the SPD output.
The SPD output is 4 pulses to earth per rev of the speedo cable.
I don't know how compatible the AE82 is with newer corolla's but if you can find a rear hub with ABS thats your best option. Cast into the hub will be teeth that the sensor will pick up on.
