Results 1 to 5 of 5
Thread: Jolting when releasing the accellerator...
    Apr 2009
    Default Jolting when releasing the accellerator...
    I looked at a ute the other day and it has a problem where you are say in second, you are driving trying to stay on say 40k's(not braking or anything).
    When you take you're foot off the accelerator it jolts or bunny hops don't know the correct terminology. Jolts like you're almost dropping the clutch or something.
    I was told by the guy its a tail shaft uni joint but thought I'd ask some opinions from people?
    If you need more detail just ask I'll do my best to explain it.
    Thanks,
    Marcus
    Default Re: Jolting when releasing the accellerator...
    Check uni joints, engine mounts, gearbox mount. If they are good, your engine tune is out to buggery. Dirty throttle body etc.
    cheers Chuck.
    MS51Crown Coupe,
    Apr 2009
    Ok thanks mate will do.
    I will have a more thorough look and get back to you with more info.
    Possibly diff related. I have a similar issue if you don't let off smoothly and it feels like it's coming from the rear of the car.
    if you've got an aftermarket computer, I'll put money on it being the tune (especially if the problem started around the time you put the computer in). Otherwise, as mentioned, check all the mounts for all your driveline components
  1. Brake caliper not releasing
    By Dale in forum Tech and Conversions
    Last Post: 10-07-2008, 10:22 PM
