Results 1 to 8 of 8
Thread: Temp Guage issues
    Junior Member Automotive Encyclopaedia JZA70R_92's Avatar
    May 2008
    Default Temp Guage issues
    Hello Guys
    Ive got an issue with my Guage after swapping to my proper supra loom it goes from C to H after 2 mins of running even though engine is cold...ive tried running a separate wire from sensor to plug on dash loom and still doing the same thing im running a 7M and no its not a BHG lol
    1992 - JZA70 STOCK - SOLD
    Default Re: Temp Guage issues
    LOL.
    Tried swapping sensors dood?
    Are you sure you connected to the temp sensor and not a thermatic switch?
    The temp sensor is generally a single spade terminal. Looks like this
    May 2008
    yep its to the correct sensor!!
    Well its either a bung sensor or bung gauge.
    If it has a 7M, this is the best solution
    The water temp gauges used on many cars equipped with 7Ms have been notoriously dodgy, including BigPerms car sitting at the lights with steam pouring out from under the bonnet and the temp gauge still sitting on "ideal"
    ive had a few 7m's and never had issues with the temp guages.
    what loom were you using before your "proper supra 1"? and was it all working fine before?
    im guessing the 7m is in a a70, is it digi dash or analogue?
    if its not wiring then id say its ur guage.
    Powered By Żywiec Backyard Mechanic Adash=P's Avatar
    South Austrlia
    Might be worthwhile to check your earths, mainly the instrument cluster.
    AE93 SX - Thrasher 20V
    JZX100 Chaser - Daily 1J lovin
    May 2008
    Yeah I will check earths...My other loom is a cressida one that has been pinned supra plugs to suit MA70 and the guage works fine. if this continues I will obtain a proper cressida loom that is uncut and wire that in my current cressida loom is good but has to many joins as it had been hack off
  1. Temp guage acting wierd
    By JZA70R_92 in forum Tech and Conversions
    Last Post: 30-06-2008, 07:48 PM
  2. High exhaust temp issues
    Last Post: 04-04-2008, 11:11 PM
  3. Reistor to change water temp guage range?
    By Bowlsclubboy in forum Tech and Conversions
    Last Post: 13-03-2008, 06:48 PM
  4. Temp Issues, ST162
    By doobs in forum Tech and Conversions
    Last Post: 26-06-2007, 06:56 PM
  5. engine temp guage
    By pushrod_POWA in forum Tech and Conversions
    Last Post: 12-08-2006, 12:07 PM
