Results 1 to 15 of 16
Thread: VL diff length
    Eltham vic
    Default VL diff length
    hi
    does anyone happen to know the overall dif lenghth disc to disc , on a vl c/dore diff
    ta
    ian
    Brisbane
    Default Re: VL diff length
    I don't, but I'm fairly sure they're a little shorter than VN onwards.
    Apr 2009
    1433mm Rear Track
    Whether that equates to the diff width i can remember, but yeh the VN is 1480mm or so. If you want a smaller track i think VB to VK are even smaller
    New Zealand
    Diff width is track width plus offsetx2, Commodore is about 40P offset (VN onwards at least, not sure on VL) so that calculates to approx 1510mm for VL and 1560mm for VN. The VN measurement corresponds to what I've measured and is the same as EA onwards Falcon.
    Callum
    If you are after a bw78 diff use the skyline or pintara, better width and better gear ratio and discs. Pintara has 2 pinon 25 spline axels 4.11 ratio, Skyline has 4 pinon 28 spline axles 3.9 ratio. Mix and match parts to make a 28 spline 4.11 ration diff as needed.
    Roger
    or use a volvo diff
    Forum Sponsor Conversion King
    Quote Originally Posted by 3jcelica
    Roger
    Yup,
    But be aware that an r31 diff is 1450mm face to face, to make it short enough to fit a celica you will have to get an axle shortened and swap the axles over so the short axle becomes the long axle.
    also be aware that they have a high pinion offset, most toyotas are 25mm or thereabouts whereas the skyline diff is 45mm which may play havoc with your trans tunnel.
    linden
    Eltham vic
    thanks for the valuable help guys
    i am just trying to get some info together for the new 28 project
    ta
    ian
    Feb 2009
    Roger
    I pretty sure only the silohette and the GTS came with the 4 pinion lsd.
    Manual skyline used a 3.7 ratio,the autos were 3.9.
    Have a look here for info.http://www.calaisturbo.com.au/showthread.php?t=133721
    1400mm axle flange to axle flange.
    Balloon Slayer Backyard Mechanic jimmmayyy's Avatar
    Apr 2007
    Roger
    which is also exactly what a VL runs except 3.45. VL and R31 run identical drivetrain. 28 spline is pretty rare nowadays.
    Junior Member Backyard Mechanic benjamin's Avatar
    Quote Originally Posted by jimmmayyy
    That's VL turbo/V8 only. NA 6 had 25 spline like pintara. And then all VN to VP ran 28 spline
    Feb 2009
    fords have a 25spline lsd,not as strong though.BW are also in chryslers.
    New Zealand
    Falcons up to XF are generally 25 spline, EA changed to the 28 spline.
    Callum
    Hi Guys,
    I am looking at doing a BW conversion on my TA22. Called nissan wreckers and they quoted complete diff axle to axle with a 3.89 ratio for $295.
    What are your thoughts?
    I am running 17X7 rims with a 40 offset, do you think I could get away with standard R31 diff width running these rims?
    Rob
    See my 3T-GTE powered TA22:
    Click Here
    Currently running 192.8rwkw @ 20PSI
    Najje,
    I think there are better options for a ta22, the skyline diff is too wide for a 22 without shortening. Look at the volvo diff or an f series diff. The lats one I picked up from u pullit for ~ $100 with discs and calipers. You also want a 4.11 unless you are running a torque motor. Centres are difficult to change on you own with out the right tools so you want to get the right centre to start with. As Witzle says use a volvo but you are up for a stud conversion.
    Roger
  1. Blown Cressida Diff
    By V8Cressida in forum Tech and Conversions
    Last Post: 07-05-2017, 12:08 PM
  2. MA61 Diff to MA70 internals?
    By UZA61 in forum Tech and Conversions
    Last Post: 31-10-2007, 06:50 PM
  3. RT142 Borg warner to R31 Diff (28 spline) conversion
    By Mickp in forum Tech and Conversions
    Last Post: 17-07-2007, 01:40 PM
  4. Diff Question
    By mlaser in forum Tech and Conversions
    Last Post: 17-04-2006, 08:13 PM
  5. GA70 diff compatibility with RT142
    Last Post: 20-03-2006, 09:05 PM
