Results 1 to 7 of 7
Thread: Where to place water feeds/returns (general Q)
    Victoria, Mt Macedon
    Default Where to place water feeds/returns (general Q)
    Folks,
    Just need to make a couple of water feeds and returns (for a turbo and oil cooler), and hoped to get some advice on where they should go. Having a think myself, it seems like:
    Feeds - from the pressure side somewhere, between water pump and thermostat.
    Returns - the opposite. After thermostat and before the waterpump, preferably before the radiator to help cooling.
    Right/Wrong? Any other factors to consider? Location not worth worrying about?
    Hen
    Default Re: Where to place water feeds/returns (general Q)
    i tee'd mine into the 2 heater lines that head down to through the center of the chassis (aw11). the heater lines are a feed and return.
    Have a look at how the factory 7M, 1G, JZ motors do it.
    Use the online TSRM for the 7M, or toyodiy.com for all of them.
    From memory the 7M comes out just behind the thermostat.
    Gangnam style Automotive Encyclopaedia beatle's Avatar
    Perth
    I'm glad this thread is here, i am doing a single conversion on my 1jz and am slightly confused about the turbo coolant points:
    am i mistaken, or should one be on the other side of the thrmostat?
    Sep 2009
    queensland
    Im in the process of the same conversion though 2j. I dont have a water cooled turbo and i dont beleive i have those bottom water lines so i am going to join the two top hoses together. Is that the right thing to do ?
    Nov 2007
    yeah i just made sure I had one water line on each side of the thermostat.
    worked a treat.
    Hoppers Crossing
    you could use the water plug/jacket drain as the feed.
    most folks normally return the water into one of the heater hoses for simplicity...
  1. 3sgte Custom Plenum and Water Piping Q's (Also Microtech)
    By medwin46 in forum Tech and Conversions
    Last Post: 22-01-2008, 12:04 PM
  2. Sam-Q's 20V RWD Cooling System Guide
    By Sam_Q in forum Engine & Driveline Conversions
    Last Post: 27-03-2007, 05:08 AM
  3. Water injection vs Intercooler
    By Gibbon in forum Tech and Conversions
    Last Post: 21-10-2006, 04:57 PM
  4. Cooling Systems - Overheating Problems.
