Do you have a new cam belt tensioner installed along with a new belt and idler? Lotsa talk about other important things in the thread, but have you had an answer as to why the engine worked for a day, then smashed valves? Did you check the relationship between actual top dead centre (TDC), and the TDC timing mark? Was the mark accurate? Does your engine rebuild manual give you a good description of setting up the timeing, and a decent picture/diagram showing the relationship between the cam and the markings in the head?. Is the cam sprocket located to the cam with a dowel, and a multiple choice set of holes, or is it a one position only cam and sprocket arrangement?.
I would like to see this one sorted, cheers Chuck.
