Results 16 to 21 of 21
Thread: timing curve(s) for 18RTE
    Junior Member Grease Monkey chris_rg's Avatar
    Tasmania
    Default Re: timing curve(s) for 18RTE
    Most turbo cars have a RRFRP. When you are on 15psi boost the fuel rail pressure only appears to be 40psi - 15psi = 25psi! So if you up the Fuel rail pressure 1:1 with the boost (what most stock turbo cars do) then the fuel pressure remains constant relative to the manifold pressure.
    It removes a non-linearity from the system
    A normal fuel pressure regulator will keep the fuel rail pressure a constant level above manifold pressure, ie 40psi. Thats why one side of the regulator is connected to the manifold.
    for example, when i'm flat out in a N/A car you have just under atmospheric pressure in the manifold, so rail pressure will be about 40psi greater than atmosphere. However when i'm cruising down a hill and have heaps of vacuum, the fuel rail pressure decreases relative to atmosphere. However, it is still 40psi relative to the manifold.
    Now 'if' i had a turbo with my standard regulator when the boost came in the regulator would be referenced to this and lift the fuel pressure as needed.
    This is the 1:1 relationship you are talking about.
    I was under the impression that RRFPR's go above 1:1 up to 1.2:1 etc. And were usually used when you were pushing the limits of your injectors to put more pressure across the injector. for example 15psi of boost and the regulator compensates with 20psi of extra fuel pressure so you end up with more than 40psi across the injector. This of course put heaps of load on your fuel pump. And the non-linearities i was talking about.
    i'm sure i've seen threads which back this up.
    i'll go searchin'
    1ggte ra40 Celica:
    - F-Series Diff + truetrac LSD
    - Corona/Pug/Hilux brake upgrade
    - Gen 1g-gte (MS1 ECU)
    Tasmania
    check out...
    http://forums.toymods.org.au/index.p...t=0#msg_823197
    or to save time quote from the 'all-knowing' oldcorollas... makes sense to me...
    normal pressure reference fuel pressure regulators will increase fuel pressure as a 1:1 ratio of the reference pressure.
    rising rate fuel pressure regulators are called that because the rate at which the fuel pressure increases is greater than the boost reference pressure, ie 1.5:1, 2:1 etc.
    a RRFPR increases fuel faster, and you run into fuel pump problems sooner. since injectors are designed for a certain range of pressure, you should keep the pressure differential across them close to their design.
    a higher differential, as with RRFPR, gives higher flow for same PW.. to a point.. and the only time they are warranted is when you are trying to richen the fuel curve of a stock setup using stock ECU which has MAP sensor, after you decrease intake flow path resistance....
    or so i think Wink.... in all other situations, you are better off using a 1:1 FPR so that you always have the same pressure differential across the injector, and then you have a better idea of what a given increase in PW will do to fuel flow..
    maybe Wink
    and
    oh, and as far as i know, most stock FPR's as 1:1 ratio. there is no need for a rising rate regualtor when you have the option of changing the tuning by programmable means.
    1ggte ra40 Celica:
    Some people get aftermarket 1:1 FPR's so that they can adjust the base pressure though. But yes you are right.
    QUICKEST 1JZ'S IN OZ
    Yah I get what you are saying now
    thechuckster has a variable RRFPR as far as I am aware.
    I've also suggested to thechuckster that having the FPR set to other than 1:1 (unless he is struggling for injector size up top) will only complicate things...
    am reasonably sure that the 'rate' is fixed - all i can adjust is the base pressure. It is a Malpassi.
    agreed - it will be interesting (and scary) to see whether i get leakage around the injectors but with fuel rail #2 being drilled correctly, i hope i'ts all OK.
    Pump is an external bosch VL pump. It sounded happy enough during static testing - rail gets up to pressure in about a second of power-on and the MS unit provides a 2-second priming pulse on booting up.
    fwiw- the rail safely holds a sustained 40psi pressure ... and i'll have 2 fire extingishers in the car with me.
    Robots! dancing robots! Domestic Engineer gearb0x's Avatar
    A tad late but this thread on MSEFI.com is very interesting
    http://msefi.com/viewtopic.php?t=9941
  1. 2tg straight cut timing gear
    By shelldrake in forum Tech and Conversions
    Last Post: 12-03-2006, 07:56 PM
  2. checking timing on car with coil on plug setup
    Last Post: 23-02-2006, 06:52 PM
  3. Delete me....
    By scootaphill in forum Tech and Conversions
    Last Post: 28-01-2006, 08:53 PM
  4. 7MGE Timing
    By rvrolla in forum Tech and Conversions
    Last Post: 19-01-2006, 06:03 AM
