tweaking the AFM is not an ideal way to tune for boost. Anyway, it would be the ECU that's tuned for different fuel.
Also - by 20/1 AFR do you mean 20:1? in which case that's lean as buggery and you're actually adding fuel to drop it down to 18:1. If not, what scale is that?
Also, the AFM isn't like the TPS - as the AFM flap moves the resistance goes up and down like a saw-tooth pattern. So changing the spring tension on it may not give you the amount of change you're after.
