Results 1 to 4 of 4
Thread: 1JZGTE MAP sensor values?
    Garage Queen Automotive Encyclopaedia ZZT231's Avatar
    Default 1JZGTE MAP sensor values?
    Hello All,
    Does anyone have a table that contains voltage vs pressure value? I've searched the xZZ3x Soarer TSRM with no luck.
    Cheers.
    Can't afford it?... Don't buy/drive it...
    James (Viper_Nipplex), We will miss you - Rest In Peace - 11 March 2009
    Default Re: 1JZGTE MAP sensor values?
    JZA70 R did just that, and even compared it to the 2JZ sensors .
    http://www.toymods.net/forums/showthread.php?t=25904
    Unfortunately, some of his links to the results arent working so check with him as he would probably still have them. But the table is as follows
    Quote Originally Posted by JZA70 R
    Thanks for the info/link.
    Cheers.
    Jeff B up in far nth Qld has been running 22+psi through the stock turbos and looking at hie Greddy Emanage Ultimate Logs, at 20+psi the Map sensor voltage still only reads 4.76-4.81 .
    11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series Soarer And 1st into the 11's WOOOT!!!
    Still going good
  1. 1JZ > 2JZ Map Sensor Upgrade Myth Burried.
    By JZA70 R in forum Tech and Conversions
    Last Post: 14-11-2008, 09:45 AM
  2. 1JZGTE ISCV & MAP Sensor Questions...
    Last Post: 11-11-2007, 05:52 PM
