Results 1 to 15 of 27
Thread: 1G-GTE into 200SX S13 - anyone tried it?
    Jun 2009
    UK
    Default 1G-GTE into 200SX S13 - anyone tried it?
    I am selling my 1G from a mkiii Supra and have a guy interested in it who wants to put it in his S13. Have any of you guys tried this? Does it fit? I would be selling the gearbox, ECU, rad etc so I assume all he'll need is a propshaft to fit to the W58. Don't suppose there is one that does this is there?
    Any info would be muchly appreciated.
    Mark
    Jun 2009
    Default Re: 1G-GTE into 200SX S13 - anyone tried it?
    it'd fit with some work,but it's a pointless conversion. noone in their right mind pulls out a 2l turbo 4cyl all alloy engine and replaces it with a 2l turbo 6cyl cast iron and alloy engine. there's nothing to gain,and a lot to lose.
    an RB series engine is a virtual drop in to a silvia,you require a skyline engine cross member,gearbox,radiator and tailshaft. you also then need thermofans,to jack up the bonnet to clear the intake if it's not altered,and besides the obvious detriment to the handling,you'll likely have overheating issues. a 1G will have all of the same problems,with the added hassle of nothing being bolt in,so you'll have to fabricate everything.
    Justin...
    Victoria, Mt Macedon
    You have a buyer interested in it? In which case the answer is "Yes, it'll drop straight in, add half a tank of juice and you'll be pulling 10s next week."
    In seriousness, I agree with fergo.
    Forking Architect Grease Monkey
    Jan 2009
    S.A.
    yes....you could
    the question is why...
    1jz is a popular choice for these cars now...but that doesnt really help you
    Rotaries are cool...so why are their owners such cocks>>?
    Jun 2009
    UK
    Thanks for the replies guys. Good points Fergo, unfortunately bad for me tho. I know of a couple of 1JZ into S13's but 1J's are much rarer/more expensive here.
    Might advertise it on here see if anyone wants it shipped over.
    If you can't get 1Js, and SR20DETs are expensive...then maybe a 1G conversion isn't such a bad idea...how much were you looking at getting for the motor over there? And what's a 1J worth over there?
    -RM.
    Jun 2009
    UK
    I spoke to the guy, he's going to spend the money on fixing his SR20.
    SR20's & 1J's aren't that rare but 1JZ are so sought after for the drifting scene that it keeps the prices up. Wouldn't like to say how much exactly tho.
    I was looking for about £400 for my 1G with 60k miles on it. I've also got adj cam gears and an F Con which i'd include for £600. What do you guys think, is that reasonable?
    Jan 2009
    S.A.
    ...if its fresh and you included the induction, injectors etc....then yeah, id call it a bargain in fact
    Has a pet Grease Monkey
    Nov 2008
    Netherlands
    1G does make sense if handling is a concern - it's shorter and lighter than a 1JZ.
    '73 TA12 Carina - pushrod power project
    '77 TA14 Carina - 1GGTE swap in the works
    '77 TA23 Celica - 1UZ swap abandoned, selling shell to someone with JZ plans...
    Um RB20 Silvertop is a bolt in conversion. Surely wouldn't be too hard to source one and would make much more sense then trying to do a 1ggte conversion.
    If in doubt power out
    Quote Originally Posted by RONA
    They aren't as bolt in as some will have you believe. Not hugely difficult, but not exactly straightforward either.
    Sr20 Anyday Over A Rb20.
    RB20 are a dime a dozen though, plus they sound a fark load better too.
    SR20's are no doubt a better motor, but if you are building a S13 drift pig on a budget plenty of CA's have been converted to RB20. Don't know why you wouldn't just get a R32,atleast they don't run the loom up through the guards which gets chewed out at full lock.
    Convictania
    yeah an rb20 with the turbo of the rb 25 goes pretty well in an s13.
    Been in one, pretty quick - looked fun.
    Jun 2009
    UK
    Quote Originally Posted by LT1986
    I wouldn't call it fresh, it's 19 years old! But it is in good condition, all cylinders pressure tested above 180psi, new cam belt, plugs, HT's & lamda recently. And yes it would be as it comes out of the car, injectors and all.
  1. Article: BHP vs HP vs kW and other power conversions
    Last Post: 06-06-2006, 11:37 PM
