Results 16 to 21 of 21
Thread: A340E (not the airbus) problems
    Default Re: A340E (not the airbus) problems
    big fucking cheers for that...
    will do this over the weekend...
    Stomps
    Nov 2007
    Get a Pinout diagram for the 1jz ECU. Find the pins for Solenoid 1, 2 and 3. Use a Multimeter to test the resistance of the solenoids. Hold the Negative lead from the multimeter onto a ground, so a piece of metal near the dash, then the positive lead you prick into the ECU pin. The resistance should be about 11 to 15 ohms if I remember correctly, you'll have to find a 1jz Workshop manual, but it should be the same, I had a 1g and I used the Supra MK3 TSRM, but about 11 to 15 ohms I think from memory.
    If you have infinite resistance, then either
    - Wiring going to the solenoid is severed somewhere
    - Faulty Solenoid
    - Bad Ground, the black coating on my solenoid mounting plate was causing a bad ground.
    Other times it could be a bad solder joint, that is on the outside of the solenoid.
    sweet... ill change fluid and check the solenoids on the weekend... cheers for all the help...
    the longer i drive it, the worse its getting... i reckon the car has just realised what we did to it at motorkhana and is dying a belated death...
    Stomps
    Junior Member Grease Monkey seamonsta's Avatar
    May 2007
    Hills Area Sydney
    I have had the same problem with my auto when cold with the car revving like a high stall and not going anywhere, it is fine when hot though. Spoke to Mike at MV Automatics and he said there is an o ring inside the box that has worn/gone hard whatever, that lets fluid past when cold then swells when hot which is why it only does it when cold, basically it is rebuild time/new box for me (maybe you too by the sound of it).
    Quote Originally Posted by seamonsta
    This was the same problem for my box. I chose to simply replace the box.
    hmmm... mine is starting to slip a little too though...
    there is no way in hell im replacing the box... if i do, it will be with a R154 not a shitty slush box... fuck spending money on autos again...
    ill try new fluid and solenoid check... if still happens.. its manual time..
    Stomps
  1. JZX81 A340E vs MX83 A340E
    By Hibba in forum Tech and Conversions
    Last Post: 26-01-2007, 12:12 AM
  2. Problems solving 4agze
    Last Post: 28-06-2006, 06:21 PM
  3. Cooling Systems - Overheating Problems.
  4. 3 problems with ae82 silver 20v
    By andy in forum Tech and Conversions
    Last Post: 15-02-2006, 10:20 AM
