Results 1 to 7 of 7
Thread: 1UZFE Wiring Issues
    Feb 2009
    NZ
    Default 1UZFE Wiring Issues
    Hey I know it's out there on the net somewhere but can't seem to find much info on 1UZ ecus. Just bought a whole LS400 parts car to donate the motor to my JZX90 Mark II(I'm a kiwi).
    Got 3 main questions:
    -What needs to be done to remove the traction control function?
    -What needs to be done to remove the 180km/h speed cut?
    -What needs to be done when swapping from auto to manual? i.e. start inhibitor switch
    Any other wiring tips would be greatly appreciated.
    Thanks
    Rob
    Eltham vic
    Default Re: 1UZFE Wiring Issues
    hi rob
    thanks for reminding me
    i have the excact same questions
    i have spent a great deal of time searching for the threads on this topic
    without much success, we may get asked to do a search ,its ok for the guys that have been raised with computers , but for old geezers like me , i am still coming to grips with electricity
    i hope they are merciful .LOL
    ian
    1. Nothing
    2. Speed cut defender
    3. Nothing
    Feb 2009
    NZ
    So will it work as normal with the traction control still fitted?
    Speed cut defender is an aftermarket thing? So I can't remove pin from the ecu or anything like that?
    If the auto is removed will it stay switched as if in Park or Neutral?
    Yes, it will behave as it the traction control doesn't exist. It actually has it own ecu, and requires all the ABS speed sensors to be installed in order to work.
    Yes, its an aftermarket unit. You can try and not wire up the SPD wire, but I can't remember if it still cuts or not.
    Will what stay switched?
    is firing on all eight. Carport Converter AndyTTR's Avatar
    The answers to some of your questions are here:
    http://www.v-eight.com/tech_forum/vi...php?f=46&t=941
  1. Replies: 271
    Last Post: 13-11-2019, 01:49 PM
  2. 1jzgte into 88hilux, jzz30 wiring help????
    By hu5tln in forum Tech and Conversions
    Last Post: 28-01-2009, 07:13 PM
  3. 4agze swap into ae110, 22pin plug wiring issues
    By Sirnixalot in forum Tech and Conversions
    Last Post: 09-01-2009, 10:53 PM
  4. Wiring Experts! Seperating looms for engine swaps?
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 29-08-2006, 06:29 PM
  5. 5mge wiring issues...
    By sticky667 in forum Tech and Conversions
    Last Post: 27-08-2006, 11:43 AM
