Results 1 to 6 of 6
Thread: tire size for 14 inch rims
    vic
    Default tire size for 14 inch rims
    hi im wondering what tyre size can i run on a 14 inch rim for ae86 sprinter without having to recalibrate the speedo? i think they're 14x6
    Last edited by driftster; 27-03-2006 at 11:49 PM. Reason: forgot vital information
    south australia
    Smile Re: tire size for 14 inch rims
    what's the standard (factory) tyre size on the 13 inch rims?
    Work out the rolling radius of tha factory tyre/rim combo and make sure it doesn't change.
    Work out the rolling radius like this:
    25.39 * (RIM DIAMETER inches) / 2 + (TYRE WIDTH mm) * ([/B]TYRE PROFILE[/B] %)/100
    eg. 13 inch tyre with 185x65x13 tyre on it gives a rolling radius of
    (25.39 * 13 / 2) + (185 * 65 / 100) = 285mm
    your speedo will read wrong if your rolling radius changes ... a 10% change in rolling radius will give you a 10% error on your speedo. Do the maths, work out what profile in the rim size and tyre width you want matches the existing rolling radius as close as possible ....
    eg. 14 inch tyre with 185x55x14 tyre on it ...
    rolling radius = (25.39* 14 / 2) + (185 * 55 / 100) = 279 mm
    ie. 2.1% smaller ... which means your speedo will read high by 2.1% - not too bad
    speedo says 60 kph, real speed: 58.7kph
    eg. 14 inch tyre with 185x60x14 tyre on it ...
    rolling radius = (25.39* 14 / 2) + (185 * 60 / 100) = 289 mm
    ie. 1.4% larger ... which means your speedo will read low by 1.4%
    speedo says 60 kph, real speed: 60.8kph
    don't know about you, but I'd rather a speedo that reads a trifle high than low.
    If this all sounds like too much hard work - google is your friend ... there are any number of tyre calculators floating around on the web.
    You're also interested in how wide you can go on a 6 inch rim - unfortunately I can't remember! Google is your friend. Bear in mind that wider tyres are not always better ... there's fuel consumption, shape of contact patch, cost of tyres etc to consider - wider may actually decrease the handling of your car - are you after high speed handling, low speed tight turnability, dirt slide/grip or what ...
    incidentally, you're in Australia .. so it's "tyre", not "tire"
    tire is what happens when you exert yourself too much - and I'm not sure you can measure that in inches!
    enjoy,
    Slapper
    Wazzzzup!? 1st year Apprentice ToranaJudd's Avatar
    Default Re: tire size for 14 inch rims
    Or if you are really lazy try this tyre calculator here.
    http://www.1010tires.com/TireSizeCalculator.asp
    Tells you the % out and what speed you will be doing compared to speedo reading at higher or lower profiles.
    Cheers, Judd.
    Junior Member Backyard Mechanic Dimitri's Avatar
    185 60 r14.
    1.4% is nothing. your speedo will always be calibrated to read a little high anyway.
    The original GT2 Backyard Mechanic draza's Avatar
    Remember that in NSW the police give you a 10% leyway when it comes to what speed your doing. I think in Vic its only 3km/h(which sucks). So 1.4% is nothing, that link say not to do anything over 3% which i would agree with.
    '87 ST162 GT2 rip
    '94 Vienta - 350,000km sent to wrecker
    '00 Avalon - Rear ended by 4WD, kept going for 4 months. Written off.
    '95 Mazda 626 - It was free...
    '88 ST162 - the love lives on.
  1. Suspension for dummies
    Last Post: 13-09-2007, 08:38 PM
  2. Tire Size Guide
    By newbien in forum Tech and Conversions
    Last Post: 12-01-2006, 12:58 PM
