Results 16 to 18 of 18
Thread: 500rpm Idle when in Drive.
    Nov 2007
    Default Re: 500rpm Idle when in Drive.
    I've allready tried that, but even at higher idle it still is rough and the car shakes a bit.
    Apr 2009
    Did it solve your 500rpm idle problem when in drive?
    you could also have any of a whole lot of other problems, what have you checked?
    any other symptoms? (the 500rpm idle ma not be related)
    Nov 2007
    Car doesn't show any other problems than that. Only other things is that I hear a rattling noise coming from the firewall when accelerating, increases with accelerating, and on cold starts the engine will shake like it's running on 3 cylinders for about 2 seconds or so, then revs go to normal idle speed.
    I've checked.
    Compression
    Spark Plugs
    Air Filter
    Timing
    Cleaned the ISCV Valve.
  1. ISCV Cleaning (*May* solve poor/erratic idle)
    Last Post: 31-08-2009, 01:57 PM
  2. Point of AFM idle screw?
    Last Post: 27-02-2006, 09:47 AM
  3. Drive shaft length
    By vtrfirestorm in forum Tech and Conversions
    Last Post: 03-02-2006, 07:15 AM
  4. Low idle??
    By JetspeedCamry in forum Tech and Conversions
    Last Post: 09-01-2006, 01:22 PM
  5. 7MGTE W58 Odd Rattle at idle...
    By RyleyMA61 in forum Tech and Conversions
    Last Post: 05-12-2005, 12:38 AM
