Did it solve your 500rpm idle problem when in drive?
you could also have any of a whole lot of other problems, what have you checked?
any other symptoms? (the 500rpm idle ma not be related)
 Re: 500rpm Idle when in Drive.
				I've allready tried that, but even at higher idle it still is rough and the car shakes a bit.
				Car doesn't show any other problems than that. Only other things is that I hear a rattling noise coming from the firewall when accelerating, increases with accelerating, and on cold starts the engine will shake like it's running on 3 cylinders for about 2 seconds or so, then revs go to normal idle speed.
I've checked.
Compression
Spark Plugs
Air Filter
Timing
Cleaned the ISCV Valve.
