Results 1 to 10 of 10
Thread: Annoying Leak
    Apr 2009
    Default Annoying Leak
    Hey guys ive started to get a pretty bad water leak out of one of the hoses under neath my car. I assume its one of the radiator hoses but i thought id see what you guys think.
    Its an MA70, 7MGTE.
    I think its this hose from the diagram
    I dont know too much about these sort of things so i thought it would be worth posting here to get other peoples opinions and to see if anyone else has had the same problem.
    At this point in time im just looking at taking it in for a full service and getting them to sort it out.
    Powered By Żywiec Backyard Mechanic Adash=P's Avatar
    South Austrlia
    Default Re: Annoying Leak
    Is hard to say just by looking at a picture. It could be coming from higher up. Is there any rust in the cooling system?
    I've had a steel pipe similar to that one get a pinhole leak once, 7M as well.
    AE93 SX - Thrasher 20V
    JZX100 Chaser - Daily 1J lovin
    Has a pet Grease Monkey
    Nov 2008
    Netherlands
    The pipes you've circled in the EPC are hard pipes and bolted to the side of the engine, not that low down under the car.
    The hoses you've circled under the car are probably from an oil cooler, since they run as a pair all the way to the front of the car.
    So the water leak must be coming from above them.
    '73 TA12 Carina - pushrod power project
    '77 TA14 Carina - 1GGTE swap in the works
    '77 TA23 Celica - 1UZ swap abandoned, selling shell to someone with JZ plans...
    Dood, it looks like you have circled the auto transmission hoses. (Hopefully no coolant leaking from them!)
    If it is a coolant leak, follow the hoses and check for coolant that could run down that line.
    Apr 2009
    Errr i just took it in for a full service, and now my car doesnt boost at all. I have no idea what the fuck they did but im not happy. If i have my foot down for more then 4k revs it just stalls and my airbox sounds like an air conditioner.
    Not happy, going to rage at them tommorow.
    Apr 2009
    Found the problem, they tore a massive hole in the hose going to my blow off valve.
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    for the water leak check the heater hose on the back of the head
    the twisting force from the motor often wears these hoses out and causes a leak.
    ive replaced 3 locally
    Apr 2009
    The leak was fixed by my mechanic for like $10 cant go wrong. Cheers for the advice though guys, i wanna start learning to do this stuff myself.
    Nov 2007
    Great stuff,
    Always remember to ask mechanics what has been done to the car, that way you can learn a few things yourself.
    Junior Member Grease Monkey gurumaster22's Avatar
    Quote Originally Posted by ecko
    This was the cause of my leak a couple of weeks ago...
    What a bitch to replace.
    Current - 1993 FZJ80 Landcruiser (Lifted, with all the usual off-road fruit)
    Previous - 1985 AE86 - RIP (Now owned by psychofox), 1975 TA22, 1976 RA23, 1971 MS55 w/7MGE, 1989 R32 GTR
  1. 4AGE 100kW Dizzy Oil Leak Guide
    By Talasas in forum Tech and Conversions
    Last Post: 05-11-2014, 09:00 PM
  2. CT12A Oil Leak (Rear).. Need advice
    Last Post: 25-03-2007, 08:28 AM
  3. Throttle body change, vacuum leak?
    Last Post: 25-07-2006, 07:15 AM
  4. Boost Leak Tester
    Last Post: 01-06-2006, 12:25 PM
  5. finding an oil leak.
    By AE101LEV in forum Tech and Conversions
    Last Post: 01-03-2006, 07:26 PM
