I think there is supposed to be a spring that goes through the hole in the end of your clutch fork then back to the slave cylinder so the piston in the slave cylinder returns properly. then you need to adjust the rod so it is longer.
If the clutch isn't working properly with the rod adjusted out longer then you may have a problem with the pressure plate or the clutch fork pivot ball might need adjusting out further.
