Results 16 to 30 of 46
Thread: What could be causing this? T50 slave cylinder issue.
    Default Re: What could be causing this? T50 slave cylinder issue.
    Will be there about 5.15 Joey Jo Jo...
    ([][][]II--LT--II[][][])
    Google images fails me, but its a c clip which holds the rod inside the slave.
    Hmmm well my old one didnt have one, nor did the new one come with one :S
    No probs Sim-bob lol.
    Mr Shabadoo.
    Daily JZX100
    Most T50 ones dont have these. They are just smooth bored, and then the clutch travel stops it from moving further. I had the same issue on my race car, i simply limited travel on the pedal
    Make sure you open the bleed valve on the slave cylinder and the plunger is all the way at the rear before you adjust the rod.
    If you keep adjusting things while the plunger isn't right at the back then it will slowly move forward.
    Jun 2008
    It's most likely a half broken fork and they flex eventually bending backwards. Also, pivot balls often break. This was a problem on Peugeot and every repairer kept a box of spare fork arms.
    Apr 2007
    As has been mentioned, the fork doesn't look right, but the slave cylinder piston was out & cocked as well .. Whats the position of the Fork look like if you pull it forward with your hand in the direction of normal travel, ( ie; away from the slave cylinder ) how much room is left for its travel before it runs out of room & hits the cut out in the Bell housing .. ( it should only have travelled about a 1/3 if that ) ...
    Tallahassee, FL USofA
    Make sure you open the bleed valve on the slave cylinder and the plunger is all the way at the rear before you adjust the rod..
    If your bleeder valve must be opened, then there is a problem, because that fluid should freely travel back to the MC & reservoir, else something is wrong with the MC, either a clog somewhere from the line going into the slave cyl., to the clevis on the MC's rod being adjusted too long so that it is getting it's piston/seal blocking it's port.
    Simon came over the other day and he diagnosed it as something to do with the fork, most likely the pins on it aren't connected to it or its not seated with the throwout bearing correctly. Either way i will have to take it apart and investigate further. Will let you guys know how it goes.
    Cheers, Joey
    Mr Shabadoo.
    Daily JZX100
    Soooo... to dig up an old thread i finally had time today to take the gearbox out and diagnose what the problem is. For the record taking the gearbox out by yourself = fail in the waiting. Some pics:
    still plenty of clutch left
    Everything was moving freely on the shaft and seemed to be working well when taken off.
    In the exploded diagram i have it shows there is an oil seal which is behind the throwout bearing, is this correct?
    There looks to be part of a metal plate on the fork broken off, could this play part in why my clutch is acting weird?
    Anyone spot anything out of the usual?
    Cheers, joe
    Mr Shabadoo.
    Daily JZX100
    Ends of fingers look a bit rounded - measure the diameter of the throwout bearing, and the hole that the fingers create - but doesn't look to big.
    But, the part that's broken is what holds the fork to the pivot, this may be causing some issues.
    Shouldnt the forks of the clutch plate be facing outwards not inwards?
    Yes.
    It's hard to see on that pic, are they facing outwards Joey?
    Well neither really, they sit dead flat. Similar to this http://blog.hemmings.com/wp-content/...04/clutch4.jpg.
    Mr Shabadoo.
    Daily JZX100
    Jun 2008
    Cuzzo has a good point and a keen eye. He might have picked something up.
  1. T50 to AZ6..... At the CNC....
    By oldeskewltoy in forum Tech and Conversions
    Last Post: 23-09-2011, 10:04 AM
  2. Clutch Slave Cylinders (W58)
    By e30-323ti in forum Tech and Conversions
    Last Post: 12-01-2006, 11:36 PM
