Results 1 to 15 of 19
Thread: SV21 camry - runs for 10 secs and dies
    Default SV21 camry - runs for 10 secs and dies
    Hi all, i have recently obtained myself a camry and it has been a smooth runner up until a couple of days ago. I was parked outside when the storms hit last week so it was exposed to a fair bit of rain and some water got through the windscreen and i went to take it for a drive on the weekend and it didnt want to go for very long.
    Problem is it will start fine and runs smoothly for no more than 10 seconds and then just die. Once its stopped it its a bit harder to start again but the same problem keeps occuring. Also it will completely hesitate to rev, everytime i touch the accelerator it dies immediately.
    Ive checked to see if the fuel pump is going - its fine
    Checked random wires in the engine bay are still fully connected/dirty or broken
    Checked air box incase of water or anything like that.
    So i am completely stumped to why this is happening any suggestions ???
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    Default Re: SV21 camry - runs for 10 secs and dies
    check idle control valve could be stuck shut, check tps etc
    what side did the windscreen leak could of leaked onto the ecu or junction box
    Slanted Photographer Automotive Encyclopaedia LeaThaL's Avatar
    Aug 2006
    my celica did this after the conversion (to a 3sfe) and we fiddled with the map sensor (i think it is) under the inlet manifold and it was fine after that so it could be that the o2 sensor also had some issue with a rusty connector also so look at that also but i could be wrong
    1 G L O V E
    88 Ga70 supra --- Under powered and over cooled Daily
    the water got through on the drivers side, couldnt see any puddles on the passenger side thankfully
    12.4 @ 110mph
    check dissy and coil, leads etc
    try and crimp/block the fuel return line and see if it runs better
    yeah that was one of my thoughts, fuel pressure. will give that a go, cheers guys!
    12.4 @ 110mph
    Team Awesome Carport Converter Pimpin_1JZ's Avatar
    Bunbury W.A.
    Lol. If your on the home page of the forum this thread comes up saying SV21 camry - runs for 10 secs...
    I was like, a 10 sec camry? I gotta see this!
    Then I got let down...
    But, It'd either be fuel or spark obviously, by the sound of it, it is an EFI. So if the fuel pump is working and it was fine up until this point, I'd be leaning more towards a spark side of things.
    1JZ MZ20 Soarer - 4AGZE KE70 Corolla - 4AGE AE86 - 4AGE KE70
    Junior Member Backyard Mechanic greywolf's Avatar
    Nsw
    I thought the same thought as Pimpin...10 sec Camry !
    My money is on a LOT of water in the distributor cap...Clean it out and dry it out.
    ha ha yeah sorry for the let down guys, it would be funny as fuck if it did run those sort's of times
    12.4 @ 110mph
    Jan 2007
    queensland
    water in the tank?
    senior backyard mechanic Grease Monkey legend's Avatar
    check the ballist restistor on the coil if it has one common fault with them
    i just brige them out to check give it a try
    building my 4agte ae82
    well the problem seems to be fixed now, cleaned the pionts on the dizzy cap and rotor, pulled the plugs off and on to check if they were loose, put a fresh 20l drum of 98 octane in, hit the engine with a hammer a few times (old school) and its now running as good as it used to. Still dont know what the problem was but meh, it runs!
    Thanks for all the help guy's much appreciated
    12.4 @ 110mph
    Bunbury W.A.
    Hit the engine with a hammer? WTF?
    Nsw
    It worked
    Good old 5S-FE's, told you it was water in the dizzy.
    Jan 2007
    queensland
    i think it was actually a 3sfe (sv21)
