Results 1 to 11 of 11
Thread: Quick Dyno Tuning question
    Junior Member Grease Monkey CoronaC's Avatar
    Default Quick Dyno Tuning question
    Just a quick question about dyno tuning, does having a speed limiter effect tuning at all or does it really make no difference?
    Same thing with power runs, would it be harder to do or again make no difference?
    Just kinda curious about this, Thanks to anyone that can help.
    Chris
    2JEJ Grease Monkey petespipes's Avatar
    Default Re: Quick Dyno Tuning question
    If you search "dyno results" i think the graphs show which gear the pulls are done in.
    If its fourth gear and you hit your speed cut ............that will be the end of your power run.
    your post might need to be-"how to bypass speed cut on bla bla motor" your tuner should bypass speed and fuel cut for you easily.Definitely sort this out before your dyno time.You are on the right track.Best of luck.
    [email protected]
    its ok not to know everything
    usually they will just use a gear where peak power is reached below the speed cut.
    im assuming its auto so you couldnt select 4th only maybe 3rd if its on your shifter.
    closest to 1:1 ratio... you could use first would give a good readout haha... most are done in 3rd that ive seen.... 5sp manual im talking about, auto id have no idea.
    Quote Originally Posted by BeRad
    depends on the ratio's! no point in running 1-1 when your 1-1 gearing is 200km/h+ etc.
    they can calibrate depending on the ratio to give the correct reading
    most 5 speeds 1:1 is 4th
    some have 3-1 and lower diff's!
    Yeah its in my celsior, so 1UZ with 4 speed auto so the runs are done in 3rd gear and it wasnt that far off hitting the speed cut (about 5-10km) last dyno day, So im just wondering if it will cause any problems. I should have asked when i called up to make the booking but completly slipped my mind until just the other day.
    Chris
    No, will be fine.
    well what has been done to the motor since then?
    if its still making power at the same rpm you shoudlnt have an issue
  1. AE10* 4a-c service & 'tuning'... Serious question.
    Last Post: 19-11-2007, 03:41 PM
  2. Toymods Dyno Day 13 - Sunday, July 2nd
    Last Post: 21-07-2006, 12:32 PM
  3. Dyno sheet from GZE tuning
    By mullett in forum Tech and Conversions
    Last Post: 11-04-2006, 08:21 AM
  4. Dyno Day 12 - Sunday January 15th 2006
    Last Post: 25-01-2006, 10:46 PM
