yes - but complicated to explain in the 2 minutes i have remaining left at work
it involves using another relay![]()
ok thanks,
would there be a better way of doing this to prevent a slow drain?
Is there any reason you want to do this chris? Most cars are wired so that the lights can still be activated without ignition or accesory power i would guess as a safety feature, much like the horn being wired with constant 12v regardless of key position.Originally Posted by mynameisrodney
You are correct, with the hi beam selected the relay switches between 87 and 87a and grounds the hi beam wire while the low beam wire is not grounded through the relay but is instead grounded through the HI BEAM indicator light on the instrument panel. I think it actually allows the low beam light to light up somewhat but it would not be noticed with the hi beams on, not to mention the majority of current is given a much better grounding path through the hi beam light.Originally Posted by bansheebuzz
lots of newer cars do this. in my dads commodore for example he leaves his lights on all the time and they turn off when he switches the car off. my magna switches off the headlights when accessories is off (but stupidly leaves the tail lights on making it way easier to not notice and still flatten the battery).
at night time its not a problem but sometimes when i drive to uni during the day i switch the lights on to drive through the harbour tunnel and then forget they are on coz it's daylight when i arrive. it's basically just one of those features that new cars have that i would like to have on the 22.
EDIT: in the commodore it's actually a bit more advanced. you can turn the car off and take the key out and the lights will stay on until you open the drivers door. they will then stay off until you next start the car. but obviously that is way too much to try and implement here.
Or you could just wire in a buzzer that goes off when you switch the ignition off with the lights on, my Mazda lets you take the key out but buzzes when you open the door.
Callum
is this what you were thinking? as far as i can tell this solves the problem, but i'm no guru on this sort of thing.Originally Posted by The Witzl
yeah i had thought of that but my gf has this setup in her astra and it just gives me the shits every time it starts beeping at me.Originally Posted by WDE_BDY
hey karl
can i ask you a huge favour mate and fix up the pics on the first page if possible?!
craig
but teh wires in the diagram arnt the same colour as in the car!
FML now the multimeter is coming out
my ra's don't go out in the dark so haven't noticed weather lights suck or not.
two 28's 1.5 23's
http://www.toymods.org.au/forums/showthread.php?t=42144
I can confirm that having four low beams is illegal.
I was pulled over by the police because as they thought I was driving around with my high beams on. After showing them that it was actually on low beam they told me it wasn't legal.
I snipped out the two wires running the inner low beams and they sent me on my way with just a warning.
I checked in the ADR catalogue I have at work and you cannot run anymore than two main driving beams. 4 high beams are fine.
Also something I noticed after converting mine is that a lot of drivers flash their lights at me thinking I have my High beams on.
It is legal in QLD however
Dansblackcat can you tell me which edition of the ADR's you are looking at?
I've had a squiz (after getting a similar statement about 4 lights from NSW RTA) at the ADR's but I can't see the limit of two driving lights you've mentioned and I had come to the conclusion I was just encountering ignorance. But it could be ingnorance on my part.
(I'm probably going to go the BMW 5 series swap just to avoid the argument, but it might be good to know about the quad convo related ADR's.
I will have a poke around at work and let you know which one I was reading. Knowing my work it was probably 30 years old.
The Phillips lighting rep told me straight away it wasn't legal but I figured stuff it and did it any way.
It might be less noticeable on a car with 4 equal sized headlights. My jag has two large and two small lights so it stands out when all four are on and really does look like you have your high beams on.
It's a shame because the light output was excellent. I now run 4 hid lights, still illegal but output is mental.
I've used one of these kits -
H4 9003 Harness Relay Halogen Headlight lamp For Toyota | eBay
Probably your cheapest option, only setup for two headlights but should be easy to mod for quad lights.
Callum
