Mate has one on gas in his 92 4runner, lots of torque for what they are, cheap to replace if needed and go for ever. Heavy on the juice because of what they are placed in however.
Hi all
Loking at buyng an RN85R ute, and the engine is leaking a bit of oil. Around the back of the engine.
Mechanic suggests that it is probably cam cover, or apparently there is an inspection plate at the back of the head.
Is anyone experienced in these engines? where is the leak likely to be? Should I be worried (are the prone to bhg?)? I guess ultimately I am not too worried - you can buy a fresh engine for around $2k.
ST185 GrpA #116
ST165 GT4 Project Car - Soon with v6 goodness.
The glass is neither half empty nor half full, rather the glass is twice as big as it needs to be.
RA23 - Twincharged
JZZ20 - Daily
This one is on gas too, in a standard 2wd sr5.
But it looks pretty suited to what we want (the surf would have been a comprimise).
I'm not even sure if it is worth an nrma inspection, the rego report only pulled up a couple of things, leaky exhaust, leaky rocker cover or inspection plate, and missing fan shroud...
ST185 GrpA #116
to put it in perspective, my mate bought the 4 runner for 2600, gas + brand new motor fitted last year.
RA23 - Twincharged
JZZ20 - Daily
Cam cover gaskets do leak with age.
Depending on Km;s, rear main seal on the crank also can leak a little (ie over 200,000K's)
Mine does both.. but not enugh to drip on the driveway if that makes sense.. I degrease the engine after every oil change at carlovers... as I always get oil over the block caus the oil filter setup being horizontal sucks... cant help but drip oil down the block...
thanks rolleraction
Hopefully the cam cover and a good wash at carlovers will do it - as I made an offer on the ute![]()
ST185 GrpA #116
