Results 1 to 6 of 6
Thread: Turbo Replacement for 3SGTE
    Default Turbo Replacement for 3SGTE
    Heya guys.....I have a ST185 GT4 with a CT26 and was wondering what would be a good replacement turbo for it without having to change injectors and ECU.
    I was thinking a KKR 330 or KKR 380 with an adapter plate and redo the Dump. I want it to be still street friendly and not laggy but still have a good response like more modern turbo cars have.
    I run a FMIC as well so dont need it to match up to a top mount.
    Tasmania
    Default Re: Turbo Replacement for 3SGTE
    a mate of mine with a type A 185 is running a kkr 430 and thats very streetable, and well priced.
    1973 TA22
    A KKR380 would be quite reasonable
    No need for fuel management mods, will make more power on less boost than the CT26, and will also hold its power further up the rev-range.
    But i doubt the response would be similar to modern turbo cars...
    27.90s @ Esses Hillclimb
    Jan 2009
    Indonesia
    Quote Originally Posted by Roundy
    Hi..,
    I would like to ask this KKR380 Turbo normally is manufactured from which company, for example: Garret or etc.
    Does Chinese company makes this kind of product ? Is it safe to use Chinese product ?
    I want to know how is the overall performance between using CT20B turbo and this KKR 380 turbo ? I heard the CT20B turbo is also suitable for street. Which is better and wch one does not need much modification ?
    Please advice.
    I am plannng to go for same kind of mods too. Please advice. Thanks.
    KKR are sold by Otomoto in Australia
    Seeing as you are in Indonesia that probably isn't that helpful.
    A chinese one could be a shot in the dark, it could be fine or it might not be, and if they fail it can wreck your engine as well.
    If you could get hold of a CT20B that may be the easiest way to go about it for you, it bolts onto the standard manifold as well
    Jan 2009
    Indonesia
    Ok thanks for the tip. really appreciate.
    Last Post: 03-05-2009, 06:47 PM
  2. 1JZ Turbo Upgrade
    By spiller in forum Engine & Driveline Conversions
    Last Post: 02-12-2008, 04:01 PM
  3. Tips for my high comp turbo gen 3 3sge
    By trd3sg in forum Tech and Conversions
    Last Post: 26-02-2008, 12:43 PM
