Results 1 to 9 of 9
Thread: 4AGZE MAP Sensor Max Boost
    Default 4AGZE MAP Sensor Max Boost
    Hey guys, does anyone know what the maximum pressure is that a 4AGZE MAP sensor can read? I'm planning what tune I'll need for the 4AGTE and I suspect I'll max out that MAP sensor before the turbo...
    I'm guessing it's not much more than 1 bar, can anyone confirm?
    Default Re: 4AGZE MAP Sensor Max Boost
    curious - what turbo are you using?
    TD04L ....10 char
    GameOn Backyard Mechanic Poggy's Avatar
    14.7psi...............
    Thanks pogs
    Emanage Ultimate has it reading to only 7psi.
    Chiba
    I'm pushing 10psi with my AE101. It certainly makes it that far.
    mine runs fine with 14psi
    its only a 2bar abosolute pressure sensor (ie. 2bar from vacuum = 1bar above sea level = 14.7psi boost).
    ...... butt scratcher?!
  1. 4AGZE Turbo Spitting/Missfireing at 3lb Boost
    By Revolution in forum Tech and Conversions
    Last Post: 15-01-2009, 09:55 AM
  2. 1JZ > 2JZ Map Sensor Upgrade Myth Burried.
    By JZA70 R in forum Tech and Conversions
    Last Post: 14-11-2008, 09:45 AM
  3. can a standard big port 4age map sensor read boost?
    By kewp in forum Tech and Conversions
    Last Post: 29-08-2007, 05:08 PM
