I'm using one of the PWR water-to-air barrell kits. Air-to-air kits are much cheaper and even the cheap ones are fairly good quality these days. A branded water-to-air setup is getting up near $2k so you'd want to be pretty serious if you were going to buy one, but in my case I knew someone who'd purchased one but never used it (apart from taking it out of the box to put a few scratches and marks on it) and paid less than half the RRP. Also in the grand scheme of things even if you did buy one at RRP the track record & aftermarket support are there, and you'll never need to worry about intake temps again. In the grand scheme of things when you're talking a minimum of $10k for an engine conversion another $2k to make it good, instead of crap, is money well spent.Originally Posted by The Last Streetfighter
I'm not made of money and don't believe in throwing it away for no reason - eg. I'll never own an engine with parts from "brand XYZ" but at the same time cars are an expensive hobby and if you cut corners it'll cost you twice as much in the long run.
I'm not really into bling, in fact I can see that looking REALLY awful... the only saving grace is that you won't be able to see the cam cover valley as the motor is on a big angleCan you make up a custom ally plate to go over your cam valley? Emboss it with GenIV 3S-GTE BEAMS or something.![]()
