Results 16 to 21 of 21
Thread: Cressida handling issues
    New Zealand
    Default Re: Cressida handling issues
    run wider tyres and/or lower tyre pressure
    what do you mean sways side to side?
    please, no more PMs!
    KE70 7AGE Grease Monkey jet81j's Avatar
    It has 17x 7 I think and 235 wide. I think it's me when I hit the Bumps around a corner and the steering being really really touchy, I'm moving the steering wheel though the corner which is making the car sway. The steering is def just too touchy for me. I just going to have to spend some time changeing the settings of the sus and possiable take the power steering off.
    Jun 2008
    Park the car. Sit on the guard or push it up and down with as much suspension movement as you can . Look to see if the wheels move in & out. If they do, you have bump steer which means the steering is set up incorrectly.
    Jun 2006
    Tasmania
    and dont just unplug your power steering it will stuff it
    Jan 2007
    queensland
    out of curiosity how's your lower control arm angles up front?? and camber..
    heaps of neg camber, (mostley in the rear) will give the car a 'nervous' feel over bumps mid corner..
    Also if you have lowered it excessivley your control arm's and steering arms will be pointing to the sky.. which will increase the effect of bump steer..
    i think you should look at both of those... as either one of them fits the description your giving
    New Zealand
    yeah +1 for bump steer
    i would be checking steering arm angles and rear suspension alignment
  1. cressida centre into hilux/hiace housing G series
    Last Post: 03-03-2008, 04:21 PM
