Results 1 to 15 of 17
Thread: supra gearbox trouble please help
    vic
    Default supra gearbox trouble please help
    Gday Guys I have done a search, but still haven't found the answers I need
    I am looking to buy a supra box preferably the w58, I have been offered one but I am having trouble working out if it is a 58 or 57.
    It has a alloy sandwich plate which I know the w57 has and some w58's.
    It has a stamp on the side of box 1-2. They are the only things that really give me any clues.Oh and in 5th gear 10 spins of the input shaft gives me 11.5 spins of the output.
    Is this box a w57 or 58?
    Is the w58 or steel sandwich box really that much stronger?
    Default Re: supra gearbox trouble please help
    You have a W57
    10/11.5 = 0.86:1
    All alloy sandwich plates are the same strength
    All steel sandwich plates are the same strength.
    Random chance it could be a W55 too.
    Best be checking first gear ratio aswell.
    vic
    Cheers mate will check that too
    S.A
    Im led to believe that there is no diff in strength ( same internals ) the only diff ( some say !! ) is that the W 58 steel plate has less flex in it due to the steel sandwich plate.
    Im putting 300+ rwkw through a W57 and have had no prob with it. Not even leaks from the sandwhich gaskets like some said may happen
    The only other diff apart from steel plate is the 5th gear ratio
    The sandwich plate supports the main bearings in the gearbox, so it's a given that the steel version is going to be more rigid and thus stronger overall than the alloy version. My personal experience is that alloy versions have a much shorter lifespan than steel ones! I have a collection of broken W5x boxes to prove it.
    Oh and later W58's are stronger than earlier W58's, but the differences are minor. Wilbo and I have compared the two side by side so this isn't just conjecture.
    vic
    Thanks for your help fellas, it's got me stuffed, I checked the first gear and it was roughly 1:3.2 which I think was w58 ratio's, will do another search. I am looking at about 200kw as well, maybe the 57 will do
    vic
    Ahh just realised the w57 and 58 have the same first gear, well it looks like she's a 57 thanks for your help, maybe I will grab it and see how it goes.
    S.A
    What are the differences you are talking about between the W58s
    There was a whole thread on this, might be on the old forums though... can't be arsed looking right now.
    Suffice to say there are minor upgrades here and there, a couple of bearings and gears are slightly wider, so in theory it's stronger but there's not much in it.
    you BROKE a COLLECTION of W5X boxes :O
    that, my friend, is impressive!
    Read this PDF (GEARBOX COMPARISION)
    I can also add to that document
    1) Alloy and Steel rear extension housings are not interchangeable
    Quote Originally Posted by love ke70
    You obviously haven't seen Norbie drive. It's not impressive...it's expected
    lol, is he like me?
    no matching revs
    just dump that bastard of a clutch
    cant find it grind
    coz if he is...respect
    No, I know how to change gears. However, a combination of 2JZ torque, torsen LSD, 255 tyres and the occasional snap-change into 2nd gear has resulted in the demise of a few gearboxes.
  1. Verifying a w58 gearbox
  2. AE86 Gearbox Conversion Options
    Last Post: 20-03-2006, 01:30 AM
  3. W58 Supra gearbox Input spline count info
    By Esteban in forum Tech and Conversions
    Last Post: 29-12-2005, 12:11 AM
